J'avais déjà acheté cet article l'année passée et la qualité de ce connecteur est toujours au rendez-vous. Même si l'on est pas obligé de souder le point chaud ,perso je préfère le souder pour un meilleur signal.
F-Type Connector PTFE Insulation for TV, Cable / Satellite
This F-Type connector HI-FM08 from Hicon is ideal to realize cables allowing the connection of TV, dish, fiber box, cable... The connector contacts are gold-plated for good conductivity and oxidation resistance and the connector benefits from PTFE insulation to limit the harmful impact of interference. The connector body is made entirely of metal.
Connector type | F-Type connector |
Plating | Golden |
Insulation | PTFE |
Max cable diameter | 8.5mm |
Connection type | To solder |
Body material | Metal |
Total dimensions | 48.6 x 13.7mm |
Colors | Golden and gray |
Max cable diameter (mm) | 8.5 |
Mounting type | To weld |
Connectic | Male |
Max panel thickness (mm) | N/A |
Impedance (Ω) | NC |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean Luc S.
tim c.
Jean Luc S.
Jean-Marc G.
