Superior class of connectors with minimal resistance and great holding. The aluminum body with gold plated contacts 24K ensures high strength and excellent durability while remaining lightweight with exceptional conductivity.
The end of T6S-F connector is removable. One Viablue connector body will be able to accomodate all Viablue's interchangeable connectors. This represents a considerable advantage from the standpoint of space usage and parts availability when adding a new device to your system or replacing an existing unit.
Except XLR connectors, connectors and body Viablue T6S share the same internal fixation system. Every body can receive the appropriate connector as needed without causing mechanical compatibility problem.
All T6s series connectors are supplied with 2 diameter reducers. These reducers allow the connectors to better adapt to the cable diameter. The small gearbox has an external diameter of 7.5 mm and an internal diameter of 4.5 mm. Thus cables with a diameter of 3 mm to 4.5 mm can be mounted securely.
The large one has an outside diameter of 9.5 mm and an inside diameter of 7.5 mm. Thus cables with a diameter of 5 mm to 7.5 mm can be mounted securely. Without reducers, cables with a diameter of 7.5 mm to 9.5 mm can be installed.
Product type | Satelite connector |
Reference | T6S |
Plating | 24k |
Conductor | OFC Copper |
Compatible cable diameters | With small gear: 3 / 4.5mm With great reducer: 5 / 7.5mm Gearless: 7.5 / 9.5 mm |
Connexion type | To solder |
Package | |
T6S-F Connector | x2 |
4.5mm Diameter reducer | x1 |
7.5mm Diameter reducer | x1 |
Max cable diameter (mm) | 9.5 |
Mounting type | To weld |
Connectic | Male |
Max panel thickness (mm) | N/A |
Impedance (Ω) | NC |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
