XANGSANE XS-6U Female BNC IC Connector 75 Ohm Gold Plated (Unit)
This Xangsane XS-6U gold-plated BNC connector for PCB soldering enables you to design a SPDIF 75 Ohm output or input.
Reference : 18161
3,50 €tax incl.
2,92 € tax excl.
Shipping date: 22-04-2025.
XANGSANE XS-6U
BNC Female 75 Ohm gold-plated PCB socket (Unit)
XANGSANE XS-6U Embase BNC Femelle 75 Ohm pour PCB Plaquée Or (Unité)
This Xangsane XS-6U gold-plated BNC connector for PCB soldering enables you to design a SPDIF 75 Ohm output or input. The contacts of this connector are protected against corrosion and oxidation thanks to their plating. Solder pins are directly 90° angled for easy PCB mounting. A nut and a clamping washer are also provided for optimum chassis integration.
Product typeBNC Female 75 Ohm connector for PCB
Connector materialPure copper
Contact platingGold
Nut internal diameter12.5mm
Recommended frame drilling diameter13-13.5mm
Max. mounting panel thickness4mm
SPDIF standard75Ω
Total dimensions35 x 20mm
Weight15g
Package1x BNC Female 75 Ohm connector for PCB XANGSANE XS-6U
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)4.0
Impedance (Ω)75
