ATOHM FURTIVE 1.1 DIY Kit 2-Way Wall Speaker (Unit)
3.0 / 5
Reference : 2268
219,00 €tax incl.
182,50 € tax excl.
Here is the DIY Kit for Atohm's FURTIVE 1.1 wall speaker. This speaker mixes elegance and acoustic performances of very high flight. Contemporary design, shallow, these features facilitate the integration in your interior.
Features:/ Strong>
  • 2-way wall enclosure close
  • Power rating: 70 watt
  • Peak power: 120 watt
  • Impedance: 6 ohms
  • Sensitivity level: 88 dB / 2.83V / 1M
  • Frequency response: 80 Hz - 30 kHz (-3dB)
  • Switching frequency: 2.5 kHZ
  • Boomer low medium: LD130CR04
  • Tweeter: New SD20
  • Filter: New 2nd order / baffle correction
  • Dimensions: 190 * 325 * 85mm / wall bracket provided
For each model kit, Atohm offers a set of studied accessories including:
  • 1 filter
  • 1 terminal block
  • 1 wall bracket
  • 4 brass spacers
  • 2 screws M4 * 20mm
  • 14 screws M4 * 25mm
  • 15 claw inserts M4
  • 1 abbreviation ATOHM
  • Wiring diagram and layout
  • Lugs and internal wiring
Please find the Kit technical sheet in the documents enclosed below.
Caution: these kits do not integrate carpentry.
bpnjour
juste pour vous dire que le plan du kit atohm furtive que vous mettez en ligne n'est plus à jour!!
cordialement
This review has been posted for ATOHM FURTIVE 1.1 DIY Kit 2-Way Wall Speaker (Unit)
