By buying this product you get 72 loyalty points
Subwoofer 220W 32Hz - 150Hz (Unit)
The Atohm Rafale VR1-X Rafale Kit is an active subwoofer capable of incredible performance. Its Bass Reflex load incorporates 220W RMS dedicated amplification coupled with an impressive 23cm diameter high-end speaker. The Rafale VR1-X’s various connection options allow it to be integrated into any type of HiFi or Home Cinema installation. It is also the ideal complement for compact loudspeakers such as libraries or small columns, offering the sitting, dynamics and breadth of a much larger system.
The LD230CRA04 is a bass speaker with a diameter of no less than 23cm, designed to provide a bandwidth between 20Hz - 200Hz. Incorporating the latest refinements of the brand, it pushes the limits of a loudspeaker of this diameter. The LDS profile suspension of the driver has almost linearity over the maximum excursion range, while maintaining perfect geometry under the most severe stresses. This suspension is combined with a progressive geometry spider, guaranteeing a wide excursion of +/-12mm. The consequent rear motorization, with a diameter of 156mm, gives the loudspeaker an important force factor with an ideal QTS. In order to drastically reduce operating noise under high amplitudes but also to ensure better cooling, the bowl and cone have large ventilation openings. The membrane itself guarantees flawless rigidity over a very wide bandwidth, even under high stresses.
The Atohm S250 amplifier module delivers 220W RMS power while maintaining a small footprint thanks to a power stage IcePower™ operating in Class D. The module offers several active filters offering many adjustment possibilities. X-Guard™ technology avoids the disadvantages of a conventional subsonic filter by ensuring that the excursion of the loudspeaker never exceeds its absolute limit, in order to avoid any breakage but also an increase in the distortion rate, regardless of the amplitude of the input signal. This technology also preserves the signal and its phase, unlike what a subsonic filter could do. The extreme bass is more accurate, the connection to the main speakers is more homogeneous and the loudspeaker is completely protected. The low-pass filter is adjustable from 38Hz to 150Hz with a slope of 12dB/oct or 24dB/oct, in order to be ideally suited for closed speakers or Bass Reflex. The latter can also be disengaged in LFE mode, so that the processor or home cinema amplifier can manage the entire cabinet. The various possible connections on this module ensure an optimal adaptation to any stereo or multi-channel home cinema system.
Product type | Speaker Kit (Without cabinet making) |
Subwoofer type | Active |
Bass Reflex Load | 27L |
Frequency response | 32Hz - 150Hz |
Amplifier model | Atohm S250-XG30 |
Bass speaker model | Atohm LD230CRA04 |
Power | RMS : 220W Max : 320W |
Acoustic pressure level | 112dBspl @ 40Hz.Pl/2st 1m |
Low level input | 2x RCA |
High level input | 2x binding posts 4mm |
Cutoff frequency | Adjustable from 38Hz to 150Hz |
Phase control | 0-180° |
Filter slope | Adjustable 12dB-24dB-LFE |
Speaker mechanical protection | X-Guard™ |
Voltage limitation and Soft Clipping | U-Guard™ |
Thermal and current amplifier protection | |
Tuning frequency | 36Hz |
Supply voltage | 230V / 115V 50-60Hz |
Consumption | 320W Max |
Color | Black |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 32 |
Highest frequency (Hz) | 150 |
Power (W) | 220.0 |
Speaker type | Active |
