ATOHM RAFALE DIY KIT SL1-X Subwoofer 220W 30Hz - 150Hz (Unit)
The Rafale SL1-X kit from Atohm is a kit for making an active subwoofer with very good sound performance. Its bass-reflex load carries a dedicated 220Weff amplification coupled to an exceptional 23cm diameter loudspeaker.
By buying this product you get 72 loyalty points
Reference : 11195
720,00 €tax incl.
600,00 € tax excl.
Atohm Kit Rafale SL1-X
Subwoofer 220W (Unit)
Atohm Kit DIY Rafale SL1-X Subwoofer 220W (Unité)
The Rafale SL1-X kit from Atohm is a kit for making an active subwoofer with very good sound performance. Its bass-reflex load carries a dedicated 220Weff amplification coupled to an exceptional 23cm diameter loudspeaker. With its many connection options, this box can be integrated without limitation in all HiFi and Home Cinema installations. The SL1-X is the ideal complement to compact loudspeakers such as libraries or small columns, offering them the seating, dynamics and breadth of a large system!
You will find in download of this sheet the detailed sheet of the kit provided.
Product typeSpeaker Kit (Without cabinet making)
Amplifier moduleATOHM S250-XG30
Speaker typeActive subwoofer
LoadCharge Close 27L
Frequency response30Hz - 150Hz
Power RMS220W
Max Power300W
Low level inputs2x RCA
High level input2x Banana plugs 4mm / Direct tightening
Cutout frequencyAdjustable from 38Hz to 150Hz
Phase control0-180°
Filtering slopeAdjustable 12dB-24dB-LFE
Bass/Medium speakerLD230CRA04
Supply voltage115V / 230V
Consumpation320Wmax
delivered components
Amplification moduleS250-XG30
SpeakerLD230CRA04
Screws M4x35mm6 piece
M4 Claw Insert M46 pieces
Agglo screws10 pieces
Logo Atohm Gold1 piece
The Rafale SL1-X kit from Atohm is a kit for making an active subwoofer with very good sound performance. Its bass-reflex load carries a dedicated...
