AMPHONY MICROFIDELITY A200 Mono / Stereo Microphone Amplifier 80W
2.2 / 5
Reference : 4617
59,00 €tax incl.
49,17 € tax excl.
AMPHONY MICROFIDELITY A200 Micro-Amplifier Mono / Stereo 40/80 Watts
New edition
Made to measure for multiroom installations and the sound of private or commercial places, the micro amplifier A200d'AMPHONY is able to provide a powerful enough to create quality musical environments
Hardly bigger than a cigarette pack, and fed by a simple power transformer 36Vprovided, it can hide virtually anywhere, and especially in any places where it is not conceivable to use a traditional amplifier.
To achieve such a level of performance in such a restricted space, the MODEL A200 is based on a Class-Dwith 2 proprietary circuits capable of a range impressive dynamics (115dB)with rates ofExtremely low distortion (0.03%) .
It also offers the flexibility to operate in Stereo or Mono , this latter mode making it possible to reach50 Watts Peak on the bridged channel .
Even at this power, its chassis aluminumis sufficient to evacuate the excess calories, dispensing it from the use of a potentially noisy active cooler.
Specifications:
  • Channel Output Power:
    • 1 x 80W RMS
    • 2 x 40W RMS
  • Total Harmonic Distortion Rate:
    • Mono: 0.04% at 30W (1KHz)
    • Stereo: 0.04% at 15W (1KHz)
  • Frequency Response: 1Hz to 70KHz (8 Ohm)
  • Dynamic range: 112 / 115dBA
  • Crosstalk L / R: 73dB
  • Yield: 85%
  • Power supply: Transformer 36V 1A
  • Power Consumption in Standby: <3W
  • Dimensions: 91 x 86 x 19mm (L x W x H)
  • Weight: 120g
  • Finish: Matt Black
https://www.audiophonics.fr/images2/4617/4617_AMPHONY_1.jpg
https://www.audiophonics.fr/images2/4617/4617_AMPHONY_2.jpg
https://www.audiophonics.fr/images2/4617/4617_AMPHONY_3.jpg
5 reviews
Au vu des avis récoltés ci et là, je comptais sur cet ampli pour alimenter une paire de colonnes dans un séjour d'une 20aine de m². Même poussé à fond, les voisins ne se sont pas plaints, et pour cause... les 2x40w ne sont pas là. Ou pas sur l'exemplaire reçu.
L'objet en lui même est sympathique, pas de chauffe particulière, simple, apparemment robuste, il sera recyclé dans le futur pour un usage moins ambitieux : enceintes plus petites ou plus sensibles, pièce plus petite ou enceintes pc ou...
This review has been posted for AMPHONY MICROFIDELITY A200 Mono / Stereo Microphone Amplifier 80W
Bonne impression tout d'abord avec des performances bluffantes mais j'ai déchanté après plusieurs mois: 3 amplis sur 5 HS.
Audiophonics m'a envoyé des remplaçants après quelques semaines, basés sur le nouveau modèle. Mais là malheureusement j'ai encore u des soucis, récemment: un des anciens et 2 des nouveaux sont HS...
Je cherche un produit de remplacement car la fiabilité n'est absolument pas au rendez-vous!
A éviter!
produit à fuir! acheté l'été 2012 , vient de griller hier, après à peine une heure de fonctionnement au total... bruit, ronflette, surchauffe; ce n'est jamais bon signe quand ça chauffe trop! et à 59€ ça reste vraiment trop cher, néanmoins je reste fidèle client audiophonics que félicite pour la qualité des produits et du service.
Sa taille est son unique point fort car cela permet de le promener et de l'utiliser pour faire tout et n'importe quoi. Par contre, sa qualité du son, il vaut mieux éviter d'en parler, tout comme l'énorme distorsion dés qu'on monte le volume. Le mien a grillé pour je ne sais quelle obscure raison mais le branchement de ce jouet est assez pénible sans interrupteur(évitez de le brancher les enceintes câblées mais câblez les enceintes après branchement).
hormis un premier ampli reçu non fonctionnel, échangé depuis, cette petite boite est étonnante. en remplacement d'un push pull d'EL34 chinois qui alimentaient une paire de Magnat 1.4 pour sonoriser la télé de la chambre ce petit monstre délivre un son dynamique, un aiguë et médium très intelligible et des basses..... qui m'ont laissé sans voix et pourtant l'EL 34 remplaçant un NAD 3020 B m'avait fait faire un bond en avant dans ce domaine. et pourtant l'alimentation est rachitique 600 milli en 36 V avec 2 Ampères je n'ose imaginer...
seule reproche même au repos il chauffe pas mal ( env. 35-40 degrés)en résumé il n'est pas aussi défini qu'un tripath 2020 mais en bas il est musclé le liliputien.
