Audiophonics STA328 DAC 24 / 96khz Digital Amplifier 2 x 60W Strong>
This class D amplifier, which can be controlled by a remote control, integrates as standard an analog digital converter 24bit 96khz.
Capable of simultaneously accepting two digital sources and one analog and with many functions (equalizer, bass volume, learning an external remote), it will prove to be the ideal companion of any digital source and also allows traditional use via its input RCA stereo.
Characteristicseristics:
- Display of the sampling rate from a digital source.
- Learning function: can be used with an external remote control
- STA 328 amplifier module: 2 x 60 w with 8 ohms
- True Direct Digital: the STA 328 is 100% digital Li>
- HP Protection Circuit
- Built-in EQ: Bass boost 1, Bass boost 2, Bass boost 1
- Red Display: 3 x 7 segments
- Memory settings / volume
- Control by remote control or rotary encoder (Power, Mute, Vol +/-, CH +/-, EQ, Bass level, Dimmer ..)
- Inputs: (Toslink Optical, Coaxial Digital and Stereo Analog)
- HP outputs: On screwed terminal blocks supporting the 4 mm banana plugs
- Inputs SPDIF natively supporting 24bit / 96khz (supported rates: 32, 44.1, 48, 88.2, 96 kHz)
Specifications: P>
- Output Power per Channel (2.0): 60W / 8Ω (1% THD + N) VCC = 35V
- Power Supply: 2 x 24V 80VA Toroidal Transformer Li>
- Dimensions: 300 x 200 x 55 mm
- Weight: 3 kg
Controls on the remote control:
- Logo Powerred:.Standby (switching off with the front panel switch) Li>
- Mute:---Mute when activated Li>
- Flight +: from -60to 00Allows to vary the volume of the amplifier
- CH + / CH-: Allows to vary the active input CH1coaxial,CH2optical,CH3analog
- mix:1-2,2.1stereo channel inversion
- EQ:E .--= Direct mode;E.00= Flat equalizer,E.13= Bass Booster 1,E.14= Bass Booster 2,E.15= Bass Booster 3
- FASHION: Input and Output of Ext Remote Learning Modeérieure Li>
- DFT: Fault (reset of all settings, including volume).
- TONE: not used in configuration 2.0 delivered
- F1: not used (factory test) Li>
- F2: Display the selected source ( CH1,CH2,CH3)
- F3: Display brightness adjustment (4 power levels) Li>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
Remote control
