Aune S1c OCXO Clock Black
The Aune S1c is a high-performance external clock with an optimized audio architecture, including an OCXO oscillator and an FS-1 frequency synthesizer designed by Titans Audio Lab, with efficient power supply and signal isolation.
By buying this product you get 134 loyalty points
Reference : 17403
1 349,00 €tax incl.
1 124,17 € tax excl.
Last items in stock !
Shipping date: 16-04-2025.
Aune S1c
Clock WCK / 10MHz OCXO
Aune S1c Horloge WCK / 10MHz OCXO Noir
The Aune S1c is a high-performance external clock with an optimized audio architecture, including an OCXO oscillator and an FS-1 frequency synthesizer designed by Titans Audio Lab, with efficient power supply and signal isolation. It provides three 10M and three WCK independent outputs and can be powered by DC or AC. The 10M outputs take advantage of Adaptive-Z technology and are therefore compatible with devices with 50Ω, 75Ω and even 10k input impedance. The WCK outputs are perfectly adapted to the 75Ω standard.
1Frequency -
2RF output selection
3Frequency +
4Output status LED indicator
5Screen
6Screen off LED indicator
7Control lock
8WCK outputs
910MHz outputs
10DC power supply input
11Power switch
12AC power supply input
Product typeClock
Outputs3* WCK outputs (1-8Fs) on BNC connectors
3* 10MHz outputs on BNC connectors
Output power10MHz: > 7dBm (50Ω)
WCK: > 7dBm (75Ω)
Output waveformSquare wave
Rise time< 2ns
Audio stability< 5ppt
Phase noise (10MHz)< -100dBc @ Offset 1Hz
< -130dBc @ Offset 10Hz
< -140dBc @ Offset 100Hz
< -150dBc @ Offset 1kHz
< -158dBc @ Offset > 10kHz
Phase jitter< ±0.02ppm
Warm-up timeBasic warm-up: 5min
Full warm-up: 60min
Supply voltage100-240VAC
15VDC 2A
Operating temepratureNormal operation : 0°C-50°C
Optimal operation : 15°C-35°C
Dimensions288*211*63mm
Package1* Aune S1c Black
1* Power cable
AUNE S1C Clock WCK / 10MHz OCXO Black
The Aune S1c is a high-performance external clock with an optimized audio architecture, including an OCXO oscillator and an FS-1 frequency...
