Aune SC1 OCXO Clock Black
The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1 frequency synthesizer designed by Titans Audio Lab, with efficient power supply and signal isolation. It provides two 10M sine wave outputs and two 10M square wave outputs with a phase synchronization of less than 0.00001°.
Reference : 17430
699,00 €tax incl.
582,50 € tax excl.
Shipping date: 27-03-2025.
Aune SC1
Clock 10MHz OCXO Sine Signal / Square Signal Black
Aune SC1 Horloge 10MHz OCXO Noir
The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1 frequency synthesizer designed by Titans Audio Lab, with efficient power supply and signal isolation. It provides two 10M sine wave outputs and two 10M square wave outputs with a phase synchronization of less than 0.00001°. It can also be powered in DC or AC. Its power supply stage incorporates a high-current, low-noise LDO to provide a clean and stable electrical signal to the OCXO clock.
1Screen
2ON/OFF outputs button
310MHz sine signal outputs
410MHz square signal outputs
512VDC power supply input
6Power button
7100-240VAC power input
8WCK outputs
Product typeClock
Outputs4* 10MHz outputs on BNC connectors
Output power> 7dBm (50Ω)
Output waveform2* square signal
2* sine signal
Frequency accuracy< ±0.02ppm
Jitter< 200Fs BW 1Hz-1MHz
Phase noise (10MHz)< -100dBc @ Offset 1Hz
< -125dBc @ Offset 10Hz
< -145dBc @ Offset 100Hz
< -155dBc @ Offset 1kHz
< -160dBc @ Offset > 10kHz
Warm-up timeBasic: 5min
Supply voltage100-240VAC
12VDC 2A
Operating temperatureNormal operating: 0°C-50°C
Optimum operating: 15°C-35°C
Dimensions288*211*63mm
Package1* Aune SC1 Black
1* Power cable
Indispensable!
Si vous possésez un dac (même ht de gamme) qui possède un entrée world clock, je vous recommande fortement l'achat de l'horloge Aune SC1...votre dac sera transcendé !
Attention, il faut attendre quelques heures avant de porter un jugement, et surtout ne jamais l'éteindre, sinon il faut réattendre quelques heures pour qu'elle soit à son optimum !
Utilisée perso sur mon Teac UD701n
This review has been posted for AUNE SC1 Clock 10MHz OCXO Sine Signal / Square Signal Black
The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1...
