Aune SC1 OCXO Clock Silver
The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1 frequency synthesizer designed by Titans Audio Lab, with efficient power supply and signal isolation. It provides two 10M sine wave outputs and two 10M square wave outputs with a phase synchronization of less than 0.00001°.
Reference : 17431
699,00 €tax incl.
582,50 € tax excl.
Shipping date: 18-04-2025.
Aune SC1
Clock 10MHz OCXO Sine Signal / Square Signal Silver
Aune SC1 Horloge 10MHz OCXO Argent
The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1 frequency synthesizer designed by Titans Audio Lab, with efficient power supply and signal isolation. It provides two 10M sine wave outputs and two 10M square wave outputs with a phase synchronization of less than 0.00001°. It can also be powered in DC or AC. Its power supply stage incorporates a high-current, low-noise LDO to provide a clean and stable electrical signal to the OCXO clock.
1Screen
2ON/OFF outputs button
310MHz sine signal outputs
410MHz square signal outputs
512VDC power supply input
6Power button
7100-240VAC power input
8WCK outputs
Product typeClock
Outputs4* 10MHz outputs on BNC connectors
Output power> 7dBm (50Ω)
Output waveform2* square signal
2* sine signal
Frequency accuracy< ±0.02ppm
Jitter< 200Fs BW 1Hz-1MHz
Phase noise (10MHz)< -100dBc @ Offset 1Hz
< -125dBc @ Offset 10Hz
< -145dBc @ Offset 100Hz
< -155dBc @ Offset 1kHz
< -160dBc @ Offset > 10kHz
Warm-up timeBasic: 5min
Supply voltage100-240VAC
12VDC 2A
Operating temperatureNormal operating: 0°C-50°C
Optimum operating: 15°C-35°C
Dimensions288*211*63mm
Package1* Aune SC1 Silver
1* Power cable
2 reviews
Excellent
Branchée sur un streamer/dac elle apporte beaucoup.
Il ne faut pas négliger le câble, le passage d'un câble basique rg58 50ohms à un plus qualitatif est indispensable pour en tirer le meilleur, sans vous rateriez quelque chose, ce serait dommage :p
This review has been posted for AUNE SC1 Clock 10MHz OCXO Sine Signal / Square Signal Silver
Indispensable!
J'ai déjà laissé un avis très positif sur l'horloge Aune SC1 noir que j'ai acheté en Décembre 2023....tellement content que j'ai acheté une seconde horloge Aune en silver pour mon second système....c'est dire! A signaler qu'il ne faut jamais débrancher l'horloge...elle met très longtemps à retrouver son optimum....et si vous pouvez l'alimenter avec une alimentation extérieur de qualité, c'est encore meilleur!
L'Aune silver est branchée sur mon second Teac ud701n, mais je l'ai testée aussi sur un Esoteric N-05XD...superbe!!
The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1...
