Aune XC1 OCXO Clock Silver
The Aune XC1 is an external master clock, using a high quality OCXO and featuring four isolated outputs, capable of operating simultaneously. Its ability to provide an extremely accurate and stable clock signal will allow you to increase the performance of your entire HiFi system.
Reference : 16519
299,00 €tax incl.
249,17 € tax excl.
Aune XC1
Master Clock OCXO 10MHz Silver
Aune XC1 Horloge Maître OCXO 10MHz Argent
Regarding the design of the XC1, in addition to its OCXO, it integrates only high quality components, including Panasonic and Sanyo capacitors or a power supply with very low noise and multi-level noise reduction.
1Display
2ON/OFF switch
39VDC Power supply
4Sine wave 10MHz output
5Sine wave 10MHz output
6Square wave 10MHz output
7Square wave 10MHz output
Product typeMaster clock
OscillatorOCXO
Output frequency4x 10MHz
Output power> 7dBm (50Ω)
Output waveform2x Square wave
2x Sine wave
Rise time< 2.75ns
Audio stability< 10ppt
Frequency accuracy< 1ppm
Warm-up timeBasic warm-up : 5min
Full warm-up : 60min
Supply voltage9VDC 1A
Dimensions145 x 171 x 45mm
ColorSilver
Package1x Aune XC1
1x Power cable
AUNE XC1 Master Clock OCXO 10MHz Silver
The Aune XC1 is an external master clock, using a high quality OCXO and featuring four isolated outputs, capable of operating simultaneously. Its...
