DENAFRIPS TERRA Master Clock Black
Denafrips Terra is a master clock generator designed for high-end audio applications. It features precision OCXO crystal oscillators (45.1548MHz, 49.152MHz), powered by a high-current, multi-stage linear power supply with an oversized O-Core transformer. As a result, Denafrips Terra delivers a highly accurate and stable clock signal that considerably reduces the jitter of an audio system.
By buying this product you get 148 loyalty points
Reference : 19124
1 480,00 €tax incl.
1 233,33 € tax excl.
Shipping date: 24-04-2025.
Denafrips Terra Master Clock OCXO Black
Denafrips Terra : Vue de face
Great attention has been paid to increasing the power supply's performance factors: low noise, high slew rate and high current. These factors provide the OCXO with an adequate DC power supply, resulting in high thermal stability and low crosstalk.
MCLK1/2/3/4 CLOCK-OUT frequencies are manually configurable via the intuitive front panel, to suit a variety of applications.
Product typeAudio clock
Fixed outputs2x 45.1548MHz
2x 49.152MHz
Adjustable outputs44.1kHz, 48kHz
11.2896MHz, 12.288MHz
22.5792MHz, 24.576MHz
Output connectorsBNC 75Ω
OscillatorsOCXO
Supply voltage100-240VAC, 50/60Hz (manual selection)
Consumption≤ 20W
Dimensions340 x 260 x 66mm
Weight6kg
Package1x Denafrips Terra
1x Power cord
DENAFRIPS TERRA Master Clock OCXO Black
Denafrips Terra is a master clock generator designed for high-end audio applications. It features precision OCXO crystal oscillators (45.1548MHz,...
