LHY AUDIO OCK-2 Master Clock OCXO 10MHz Green
The LHY AUDIO OCK-2 master clock is a high-precision clock that minimizes sampling errors from your Hi-Fi system, particularly for high-resolution audio streams. The OCK-2 clock features 6 independent 10MHz 50Ω outputs on BNC connectors. Thanks to a high-performance OXCO oscillator, three outputs have a sine wave, while three others have a square wave.
By buying this product you get 73 loyalty points
Reference : 18681
739,00 €tax incl.
615,83 € tax excl.
Photo of LHY AUDIO OCK-2 master clock
The LHY AUDIO OCK-2 master clock is a high-precision clock that minimizes sampling errors from your Hi-Fi system, particularly for high-resolution audio streams. The OCK-2 clock features 6 independent 10MHz 50Ω outputs on BNC connectors. Thanks to a high-performance OXCO oscillator, three outputs have a sine wave, while three others have a square wave. This master clock system greatly enhances the performance of your audio installation. The LHY Audio clock incorporates quality components such as an OXCO oscillator, a linear power supply delivering a clean, pure signal with EMI filter, Talema 15W transformer and high-speed rectification filter. The crystal oscillator is powered by 3 LT3042 + PNP voltage regulators, enabling it to achieve a high level of precision.
Photo of the inside of the LHY AUDIO OCK-2 master clock
LHY AUDIO OCK-2 master clock rear panel overview
LHY AUDIO OCK-2 master clock connectivity diagram
13x 10MHz 50 Ohm sine wave clock output on BNC connector
23x Clock output 10MHz 50 Ohm square wave on BNC connector
3IEC power supply / Fuse
Technical caracteristics
Product typeMaster Clock
OscillatorOCXO
Output waveforms3x Sinusoidal signal
3x Square-wave signal
Output frequency6x 10MHz
Output impedance50 ohm
Power supply220-240V AC
Power consumption< 20W
Dimensions240 x 175 x 50mm
ColorGreen
Weight2.1kg
Package1x Master clock OCXO 10MHz LHY AUDIO OCK-2
1x Schuko power cable
The LHY AUDIO OCK-2 master clock is a high-precision clock that minimizes sampling errors from your Hi-Fi system, particularly for high-resolution...
