LHY AUDIO OCK-2S Master Clock OCXO 10MHz Silver
The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams. This clock features six independent 10MHz 50/75Ω outputs on BNC connectors, including three sine-wave and three square-wave outputs. Based on a high-performance OCXO oscillator, it significantly improves the performance of any Hi-Fi system.
By buying this product you get 119 loyalty points
Reference : 19894
1 199,00 €tax incl.
999,17 € tax excl.
Shipping date: 22-04-2025.
LHY Audio OCK-2S Master Clock OCXO 10MHz Silver
Photo of LHY Audio OCK-2S clock
Inside, you'll find quality components, including a linear power supply delivering a clean, pure signal with EMI filter, Talema 15VA transformer and high-speed rectification filter. The crystal oscillator is powered by three LT3042 + PNP voltage regulators, guaranteeing a high level of precision.
Photo of the inside of the LHY AUDIO OCK-2S clock
LHY-Audio OSK-2S overview
13x 10MHz 50/75Ω sine wave clock output on BNC connector
23x 10MHz 50/75Ω square wave clock output on BNC connector
3Power input / Fuse / Bouton de mise sous tension
Product typeMaster clock
OscillatorOCXO
Output waveform3x Sinusoidal signal
3x Square-wave signal
Output frequency6x 10MHz
Output impedance50 ohm
75 ohm
Frequency stability< ±5ppB
Frequency accuracy< ±0.05ppm
Output noise≤ -110dBc @ 1Hz
Short term stability< ± 2x10-12 @ 1s
Preheating time15min
Power consumptionPreheating: 8W
Operating: 5W
ColorSilver
Dimensions240 x 50 x 175mm
Weight2.1kg
Package1x LHY AUDIO OCK-2S OCXO 10MHz master clock
1x Schuko power cable
The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams....
