Insulated Female Blade Terminal 4.8mm Ø3mm (x10)
These lugs accept cables up to 3mm and will allow you to easily connect your speakers. In addition, they are made of a Copper alloy to ensure good electrical conductivity. Each lug comes with a clear plastic sheath.
Reference : 14320
3,00 €tax incl.
2,50 € tax excl.
Shipping date: 05-03-2025.
Female lugs
4.8mm Ø3mm (Set x10)
Cosses femelles 4.8mm Ø3mm (Set x10)
Requires welding.
Product typeFemale lugs
Max cable diameter3mm
MaterialCopper alloy
Internal width4.8mm
Total dimensions14.5 x 5.6 x 2.4mm
Quantity10
Max cable diameter (mm)3.0
Section (mm²)N/A
ConnectorBlade connectors
Très bien
Très bien
This review has been posted for Insulated Female Blade Terminal 4.8mm Ø3mm (x10)
These lugs accept cables up to 3mm and will allow you to easily connect your speakers. In addition, they are made of a Copper alloy to ensure good...
