AUDIO-GD PSU-2019 Linear Power Supply Unit Regulated 12V
Reference : 13916
37,90 €tax incl.
31,58 € tax excl.
Shipping date: 14-01-2025.
Audio-GD regulated linear power supply 12V
Linear power supply module by Audio-GD. Operates in pure class A with positive or negative dual output.
Uses exclusively high quality components (Nover, WIMA capacitor and Toshiba transistors) for an extremely neutral impact on the sound. This module is ideal for circuit that are very sensitive to power noise and need little current such as DA, DAC, preamplifier stage, OPA... etc.
The operation in pure class A has a high input impedance and low output impedance. This allows for a very fast output response while maintaining an extremely low current.
Connections
If the input voltage is at its maximum value (shown in the table below), please change heatsinks or mount the transistors directly on the chassis.
Dimensions
TypePower supply
Pure class A
Idle current80mA
Temperature range0-85°C
Dimensions89x51x45mm
Voltage range (max current) Input15-24VDC (80mA)
15-22VDC (120mA)
output voltageDouble +12V ou double -12V
InputSolder pad
OutputSolder pad
Output voltage (V)12.0
Output current (A)0.1
Input voltage (V)15.0
Input voltage (V)24.0
Input voltage (V)22.0
Power SupplyLinear
