AUDIO-TECHNICA ATH-M30X Closed-Back Dynamic Headphone Ø40mm 47Ω 96dB 15Hz-22kHz
-22%
Audio Technica's ATH-M30x closed dynamic headphones are an improved version of the ATH-M30 and ATH-M35. The ATH-M30x boasts greater clarity and better sound isolation. It offers faithful reproduction of the original signal, with clear highs, precise midrange and well-defined bass. Versatile, affordable and of high quality, it is also suitable for professional use. It features 40mm diameter transducers, a frequency response of 15Hz - 22kHz and a sensitivity of 96db.
Reduced price!
Reference : 18006
Limited special offer
89,00 €tax incl.
-22%
69,00 €tax incl.
57,50 € tax excl.
Closed-back Dynamic Headphone Ø40mm 47Ω 96dB 15Hz-22kHz
AUDIO-TECHNICA ATH-M30X Casque Audio Dynamique Fermé Ø40mm 47Ω 96dB 15Hz - 22kHz
Quality transducers
The ATH-M30x's transducers are designed with a neodymium magnet and a CCAW (copper-coated aluminium) voice coil. Thanks to the 40mm diameter transducers, the soundstage of Audio Technica's headphones is wide and detailed. The CCAW coils ensure a perfect tonal and vibratory balance.
The ATH-M30X's wide range of applications
Despite its affordable price, the ATH-M30x rivals much more expensive headphones in terms of performance, with sound reproduction adapted to studio standards. It's the ideal companion for recording instruments and vocals, as well as for production and mixing. Its sound-isolating circum-aural design also makes it suitable for DJs working in noisy environments.
Comfortable, practical headphones
On the left-hand side of the headphones is a 3m-long soldered cable with a Jack 3.5mm termination. Foldable and lightweight, the ATH-M30x is easy to transport. The padded earpads and headband make them particularly comfortable for extended listening sessions. The headphones can be rotated by 15°, making them flexible. A Jack 6.35mm adapter is also supplied to extend connectivity.
Product typeHeadphone
Headphone typeDynamic
Circum-aural closed-back
Transducer diameter40mm
MagnetNeodymium
Voice coilCCAW (Copper-coated aluminum)
Frequency response15Hz - 22kHz
Maximum input power1300mW @ 1kHz
Sensitivity96db
Impedance47Ω
Cable3m non-detachable cable (left side)
ConnectorGold-plated 3.5mm jack
Foldable
Net weight (without cable)220g
Package1* Audio Technica ATH-M30X
1* Jack 6.35mm adapter
Impedance (Ω)47
Efficiency / Sensitivity (dB)96.0
Lowest frequency (Hz)15
Highest frequency (Hz)22000
WirelessNo
Audio Technica's ATH-M30x closed dynamic headphones are an improved version of the ATH-M30 and ATH-M35. The ATH-M30x boasts greater clarity...
