AUDIO-TECHNICA ATH-MSR7B High Fidelity Balanced Headphone 101dB 36 Ohm 5Hz - 50kHz
The Audio-Technica ATH-MSR7b headphones offer you the latest high-resolution headphone technology, combining the advanced features of the ATH-MSR7 with both standard and balanced connection options for the ultimate listening experience, revealing detailed and spatial reproduction.
3.0 / 5
Reference : 14382
249,00 €tax incl.
207,50 € tax excl.
Audio-Technica ATH-MSR7b Casque Haute Fidélité Symétrique 101dB 36Ω 5Hz - 50kHz
Balanced connectors
The ATH-MSR7b's great feature and strength is its symmetrical connection system and a detachable 4.4mm Pentaconn cable. The headset is also delivered with an unbalanced 3.5mm jack cable for a classic connection. The headphones are therefore very versatile, being compatible with all audiophile players on the market.
The Balanced connection drastically reduces noise and distortion for incredibly accurate and rich playback.
45mm Loudspeakers
The ATH-MSR7b features large 45mm diameter True Motion transducers with a Carbon Diamond coated diaphragm to provide distortion-free sound reproduction with a wide frequency response. The headphones also take advantage of multi-layer air technology to effectively reduce unwanted vibrations and control airflow for exceptional sound clarity.
A comfortable and ergonomic headphone
The headphones feature thick memory foam ear pads and a padded headband for a comfortable fit and long listening sessions. The headset is a closed, circumaural design. The large earcups swivel on two axes to easily adapt to the shape of your face or for easy storage.
Transport bag
The MSR7b comes with a soft carrying pouch. This makes it easy to protect and transport the headset.
Product typeHeadphone
Headphone typeDynamic
Closed
Circumaural
CouplageCircumaural
DriversDynamic "True Motion"
Diameter : Ø45mm
Carbon Coated Membranes
Multi-layer damping technology
Ear pads cushionsMemory foam
Head bandPadded
Pivoting earpads90°
Sensitivity101dB/mW
Frequency response5Hz - 50kHz
Max. power2000mW
Impedance36Ω
Weight237g
Package1x Audio-Technica ATH-MSR7b
1x Single-ended Jack 3.5mm Gold plated cable 1.2m
1x Balanced Jack 4.4mm Pentaconn Gold plated cable 1.2m
Transport bag
Impedance (Ω)36
Efficiency / Sensitivity (dB)101.0
Lowest frequency (Hz)5
Highest frequency (Hz)50000
2 reviews
Visuell fiasko
Le son est bon. En revanche, la finition est misérable. Les coutures sont tordues et inesthétiques. J'ai une photo, mais comment la télécharger ? En raison de la mauvaise finition, je ne recommande pas l'achat.
This review has been posted for AUDIO-TECHNICA ATH-MSR7B High Fidelity Balanced Headphone 101dB 36 Ohm 5Hz - 50kHz
Un casque compétent !
Les + : Un son clair et détaillé, confortable, un bon rendement et facile à alimenter.
Les - : Qualité du similicuir des coussinets.
Le son de ce casque se rapproche de la neutralité des casques de studio, mais avec un plus de chaleur dans le bas du spectre, et des aigus moins agressifs.
Appairé avec un Fiio BTR3, je modifie l’équaliseur pour lui apporter un peu plus de kick dans le bas du spectre, les basses sont alors tendues et rapides, un régal !
Dans les films, cette configuration apporte un plus dans les explosions qui deviennent plus percutantes.
En mode bureau, je le l’utilise avec un le zen dac (ifi) et la sortie symétrique 4.4 pentaconn.
Ici la scène sonore s’ouvre un peu plus. De temps en temps j’active l’option truebass du dac qui enrichi les basses sans excès.
J’habite en région tropicale et le similicuir des coussinets a commencé à se désagréger au bout d’un an est demi, je les ai changé par une paire de (très bon) coussinets trouvé chez DEKONI audio
The Audio-Technica ATH-MSR7b headphones offer you the latest high-resolution headphone technology, combining the advanced features of the ATH-MSR7...
