AUDIO-TECHNICA ATH-S220BT Wireless Closed-Back Dynamic Headphone Ø40mm 32 Ohm 105dB 5Hz-32kHz
The ATH-S220BT from Audio-Technica is a dynamic, closed-back wireless headphone that offers clear sound reproduction, 60 hours of battery life and multi-point connectivity. Lightweight and adjustable, the ATH-S220BT is designed for maximum comfort, allowing it to accompany you during long listening sessions.
Reference : 17121
67,00 €tax incl.
55,83 € tax excl.
Shipping date: 24-04-2025.
Audio-Technica ATH-S220BT
Closed-back Dynamic Wireless Headphones Ø40mm 32Ω 105dB 5Hz-32kHz
Audio-Technica ATH-S220BT Casque Audio Dynamique Fermé Sans-Fil Ø40mm 32Ω 105dB 5Hz-32kHz
With a 40mm diameter transducer, the ATH-S220BT delivers dynamic, musical and accurate sound and is as effective for listening to music as it is for immersing yourself in your favorite movies.
Practical, the headphone can work in wireless mode thanks to the integration of a Bluetooth 5.0 receiver, allowing you to broadcast your music from a smartphone or a tablet for example. It also allows a multipoint pairing to connect your headphone simultaneously to several devices.
Running on battery, it also offers a consistent autonomy of 60 hours, complemented by the support of fast charging, 10 minutes of charging then guaranteeing 3.5 hours of listening. It also features a microphone and control buttons for easy call answering and music playback. The ATH-S220BT headphones also come with a 1.2m cable that includes a microphone and remote control for wired listening.
Product typeHeadphone
Headphone typeDynamic
Closed-back
Wireless
Transducers diameterØ40mm
Frequency response5Hz - 32kHz
Sensitivity105dB/mW
Impedance32Ω
BatteryLiPo 3.7V DC
Battery life~ 60h (playback)
Charging time~ 4h
Integrated microphone
Microphone typeElectret capacitor
Microphone sensitivity-42dB (1V/Pa @ 1kHz)
Frequency response of the microphone50Hz - 4kHz
Microphone directivity curveOmnidirectional
Bluetooth version5.0
Max reception distance10m
Weight (without cable)180g
Package1* Audio-Technica ATH-S220BT
1* USB charging cable 30cm
1* USB-A to USB-C cable with integrated microphone and remotre control 1.2m
1* Jack 3.5mm adapter
Impedance (Ω)32
Efficiency / Sensitivity (dB)105.0
Lowest frequency (Hz)5
Highest frequency (Hz)32000
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorWireless (Bluetooth)
Headphone / Earphone connectorJack 3.5mm
The ATH-S220BT from Audio-Technica is a dynamic, closed-back wireless headphone that offers clear sound reproduction, 60 hours of battery life and...
