AUDIO-TECHNICA ATH-S300BT Wireless Headphone Black
New
The Audio-Technica ATH-S300BT headphones, big brother of the ATH-S220BT, are closed, dynamic wireless headphones whose main strength lies in their 90-hour battery life, without sacrificing the quality of the sound they deliver. In fact, a Ø40mm transducer delivers clear, immersive sound for a qualitative listening experience, whether musical or cinematic. Other features include multipoint connectivity via Bluetooth 5.1, hybrid digital noise reduction and an integrated microphone.
Reference : 20664
105,00 €tax incl.
87,50 € tax excl.
Audio-Technica ATH-S300BT Closed-Back Dynamic Wireless Headphone Bluetooth 5.1 Ø40mm 44.5Ω 103dB 20Hz-20kHz Black
AUDIO-TECHNICA ATH-S300BT picture
The Audio-Technica ATH-S300BT headphones, big brother of the ATH-S220BT, are closed, dynamic wireless headphones whose main strength lies in their 90-hour battery life, without sacrificing the quality of the sound they deliver. In fact, a Ø40mm transducer delivers clear, immersive sound for a qualitative listening experience, whether musical or cinematic. Other features include multipoint connectivity via Bluetooth 5.1, hybrid digital noise reduction and an integrated microphone. In addition to its wireless connectivity, Audio-Technica has equipped its ATH-S300BT headphones with a 3.5mm jack for wired listening. There's also a USB-C port for recharging, with fast charging providing 2.5 hours of autonomy in just 3 minutes of charging.
Benefits of the AUDIO-TECHNICA ATH-S300BT
Audio-Technica ATH-S300BT: 90-hour battery life
The main strength of the Audio-Technica ATH-S300BT headphones lies in their battery life, which offers up to 90 hours of use. In addition, the quick charge feature allows you to gain up to 2h30 of autonomy in just 3 minutes. This makes the ATH-S300BT the perfect ally for everyday use and travel.
Autonomy of the AUDIO-TECHNICA ATH-S300BT
Active noise reduction on the AUDIO-TECHNICA ATH-S300BT
Audio-Technica ATH-S300BT: hybrid digital noise reduction
Ambient noise is reduced thanks to the integration of small MEMS microphones within the headphones' shells. When activated, noise reduction is achieved by both anticipation and feedback, for greatly optimized rendering. On the other hand, the “hearthrough” function lets you remain attentive to the outside environment.
Connectivity of the AUDIO-TECHNICA ATH-S300BT
Audio-Technica ATH-S300BT: Bluetooth and wired connectivity
The ATH-S300BT features Bluetooth 5.1 functionality and supports AAC and SBC codecs for reliable, stable reception at ranges of up to 10m. In Bluetooth mode, it's also possible to enjoy multipoint pairing for the smoothest possible experience. A 3.5mm jack input enables wired listening if required. A 3.5mm jack to 3.5mm jack termination cable with microphone is supplied. In wired mode, the ATH-S300BT headphones are easy to drive, given their 44.5 ohm impedance and 103dB sensitivity, making them ideal for use with a wide range of sources.
Product typeHeadphones
Headphones typeClosad-back dynamic
Transducer dimensionsØ40mm
Frequency response20Hz-20kHz
Sensitivity103dB/mW
Impedance44.5Ω
AutonomyContinuous music playback:
Up to 60 hours (Bluetooth and noise reduction enabled)*
Up to 90 hours (Bluetooth and noise reduction deactivated)*
* These data depend on operating conditions.
Charging timeApprox. 2h30 *
Battery time3.85V DC (Lithium-Polymer battery)
Microphone typeHeadphone: MEMS
Cable: condensator
Microphone directivity curveHeadphones: omnidirectional
Cable: omnidirectional
Microphone frequency responseHeadphones: -38dB (1V/Pa, at 1 kHz)
Cable: -42dB (1V/Pa, at 1 kHz)
Bluetooth versionBluetooth 5.1
Supported Bluetooth codecsSBC, AAC
Frequency band2.402GHz - 2.480GHz
Compatible Bluetooth profilesA2DP, AVRCP, HFP, HSP
Transmission methodFHSS
Content protection methodSCMS-T
Weight258g
Package1x Audio-Technica ATH-S300BT headphones
1x 3.5mm jack cable to 3.5mm jack termination with microphone
1x USB-A to USB-C cable
Impedance (Ω)44.5
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationJack 3.5mm
Headphone / Earphone connectorWireless (Bluetooth)
Headphone / Earphone connectorJack 3.5mm
AUDIO-TECHNICA ATH-S300BT Headphone Closed-Back Dynamic Wireless Bluetooth 5.1 Ø40mm 44.5 Ohm 103dB 20Hz-20kHz Black
The Audio-Technica ATH-S300BT headphones, big brother of the ATH-S220BT, are closed, dynamic wireless headphones whose main strength lies in their...
