AUNE AR5000 Open-back Dynamic Headphone
Aune's AR5000 are open-back headphones with a dynamic MLD ("Multi-Layer Distributed") driver of no less than Ø50mm. Thanks to its innovative driver, high-tilt acoustic structure and concentric-circle port system, these headphones deliver rich, detailed reproduction over a wide soundstage.
By buying this product you get 32 loyalty points
Reference : 18625
329,00 €tax incl.
274,17 € tax excl.
Shipping date: 18-04-2025.
AUNE AR5000 Open-back Dynamic Headphone Ø50mm 28Ω 108dB 5Hz-41Khz
Photo of AUNE AR5000 headphones
Aune's AR5000 are open-back headphones with a dynamic MLD ("Multi-Layer Distributed") driver of no less than Ø50mm. Thanks to its innovative driver, high-tilt acoustic structure and concentric-circle port system, these headphones deliver rich, detailed reproduction over a wide soundstage. They deliver deep, powerful bass for immersive sound, as well as a high level of comfort for long listening sessions. Aesthetically too, Aune has got it right, with champagne gold plating and meticulous finishes such as CNC-machined curves. A detachable 2x jack 3.5mm to jack 3.5mm termination cable is supplied with the Aune AR5000. Here are the various highlights of the Aune AR5000 headphones:
  • Open-back design
  • Innovative Ø50mm dynamic driver
  • MLD (Multi-Layer Distributed) diaphragm
  • 28 Ohm impedance and 108dB sensitivity for high compatibility
  • Frequency response: 5hZ-41800Hz
  • Low distortion
  • Comfort and lightweight
  • Variable-size headband
Exploded view of Aune AR5000 headphones
Aune AR5000: dynamic driver with MLD diaphragm
The Aune AR5000's dynamic driver delivers a sound reproduction of high purity and stability. In fact, its Ø50mm MLD diaphragm offers a balance between rigidity and damping that significantly reduces distortion across the entire frequency response range. The result is transparency and a high level of detail.
Photo of the Aune AR5000 dynamic driver
Photo of Aune AR5000 airflow system
Aune AR5000: innovative acoustic design for powerful bass
The acoustic structure of the Aune AR5000 features suspensions that improve airflow and thus the linearity of diaphragm movement, equalizing internal pressure. The result is a smooth, dynamic performance with deep, powerful bass.
Aune AR5000: comfort and lightweight
These circum-aural headphones feature a concentric circle adjustment system and a very lightweight structure for comfort even during very long listening sessions. The foams are made of breathable material with a slow acoustic rebound.
Photo of Aune AR5000 headphones
Aune AR5000 headphones tested by Audio Science Review
"The AR5000 starts with looks that rival and beat headphones in multi-thousand dollar price range. Out of box tonality lacks some bass and treble which is easily remedied with equalization. Once there, combine with its very high sensitivity, you have a delightful headphone to listen to."
Audio Science Review Logo
Aune AR5000: exceptional performance
Aune AR5000 measurement curves
Product typeOpen-back headphones
Driver typeDynamic with MLD technology
Frequency response5Hz-41kHz
Nominal impedance28 Ohm
Sensitivity108dB (@ 1kHz, 1Vrms)
THD<0.03% (@ 1kHz, 100dB SPL)
Cable typeDetachable
Heaphone connectors2x Jack 3.5mm
Cable terminaisonJack 3.5mm
Cable length1.5m
Dimensions195 x 220 x 115mm (LxHxP)
Net weight350g
Package1x Aune AR5000 headphones
1x Cable 2x jack 3.5mm stereo to termination jack 3.5mm stereo
ColorChampagne
Impedance (Ω)28
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)5
Highest frequency (Hz)41800
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
2 reviews
True reference performer
Neutral, transparent, never harsh sound.
Very solid and robust aluminum design but yet comfortable.
I'm using these as reference headphones in my system.
Highly recommended.
 (3)
This review has been posted for AUNE AR5000 Open-back Dynamic Headphone Ø50mm 28Ω 108dB 5Hz-41Khz
Fucking Amazin
I love these headphones.
Ligthweight, good build quality, amazing soundstage and neutral tuning. For me its the spirital successor to the HD600
 (4)
Aune's AR5000 are open-back headphones with a dynamic MLD ("Multi-Layer Distributed") driver of no less than Ø50mm....
