ERGO 2 TWO High-End Hi-Fi Hi-Fi Dynamic Headphones
4.0 / 5
By buying this product you get 32 loyalty points
Reference : 6198
329,00 €tax incl.
274,17 € tax excl.
Shipping date: 24-04-2025.
This unique product in its design represents for us simply the best value for money of the high-end headphones market.
During the development of the ERGO helmet, man and especially the anatomical structure and acoustic functions of the ear, were amply considered. Its form, truly unconventional, is a purely functional and natural solution. Several years of scientific research are at the origin of the drawing, with the following arguments:
  • TheThe weight of the helmet is distributed over the less sensitive areas of the head, the layer of foam allowing the skin to "breath".
  • Thelarge-area transducer panels are placed in front of the ear flaps, with the correct scattering angle, so as to transmit the sound under optimal conditions.
  • CThis arrangement allows free air access from the bottom, so that the auricle can not overheat.
Traditional headphones eliminate the natural function of the auricle. The sound is "injected" directly by a small transducer, almost in the ear canal. The important information of the second acoustic track is practically annuEEA. The natural heat exchange function of the auricle is obstructed by the fact that the ear is crushed against the head, or is completely wrapped.
ecoute at high level, usually practiced with traditional helmets is probably due to the absence of the second sound track.
The soundthe ERGO headphones are distinctly different from other headphones.
The reproduction is clear, clear and perfectly natural ...
The ERGO 2 is also equipped with two superior dynamic transducers with a softer membrane. The ERGO 2 gives a linear, intense, clear and colorless reproduction. Its sound quality comes close to the electrostatic headphones.
"InHigh-end helmet material, there was Stax, and there was Jecklin Float.
Jecklin Float was to the helmets what the electrostatic panels were in the enclosures, with one thing that the other helmets did not give: the impression that the sound comes from elsewhere, and gives a kind of transparency, space which exceeds the size of the helmet.
The famous Jecklin Float comes back through the Ergo, and it is with this headset that you will understand what I mean when I say that no speaker in the world can achieve the quality of a great helmet.
For the price of an Ergo, you will flirt with the limits of Hi-fi, you will taste the thrills of the ultra high fidelityé, and you will discover a sound reproduction that you will never hear with speakers. At home, or in a Hi-fi room, or at the most delusional amateur. ''
Jean Patrick Grumberg
Characteristics :
  • Technology: large dynamic transducer
  • Frequency response: 30 Hz - 20 kHz
  • Sound Pressure: 94 dB
  • Harmonic distortion: <0.5%
  • Cable length: +/- 2.8 m
  • Weight: 385 g
  • 6.35 mm jack connector
Note : Headphone support sold separately
Impedance (Ω)NC
Lowest frequency (Hz)30
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 6.35mm
4 reviews
Sans plus ...
Pour les porteurs de lunettes le port de ce casque pince celles-ci et décolle les lunettes du nez . Sans lunettes le port manque clairement de confort . Le son ne pas convaincu mais je souligne que je n'ai pas eu la patience d'attendre le rodage malgré un léger mieux après dix heures d'écoute . ( son de boîte ).
This review has been posted for ERGO 2 TWO High-End Hi-Fi Hi-Fi Dynamic Headphones
Inhabituel mais vraiment excellent
J'ai acheté un Ergo Model 2 sur le conseil d'un ami, sans l'avoir essayé auparavant. A son arrivée, gros choc devant l'aspect massif de la bête : du coup, j'ai mis plus d'un an avant de vraiment lui donner sa chance, lui préférant jusque-là le Sennheiser HD555 qu'il était censé remplacer pour les séances Home cinéma nocturnes. Je l'utilise en continu depuis un mois, à peu près tous les soirs, et le rodage a vraiment fait de l'effet. Après une trentaine d'heures, on découvre un casque à la sonorité TRÈS au-dessus de son prix : bel équilibre, grande richesse de tonalité - avec un fourmillement de détails présentés sans aucune duret, avec un équilibre frappant entre précision, richesse harmonique, et "liquidité". Grande cohérence à travers tout le spectre, aigu filé mais jamais sibilant, médium riche, grave - absent avant rodage - très beau, assez profond mais surtout très bien défini et contrôlé. Et puis, le gros point fort : la scène sonore, très large latéralement et très profonde, avec une précision franchement diabolique dans la spatialisation. Comme il est facile à driver, il est branché sans ampli sur un pre pro Marantz AV 7005 qui gère le Dolby Headphones : la sensation d'espace qu'il est capable de re-créer est hallucinante... Avec une seule limite : il est quand même BIEN massif, et sans être inconfortable, il ne se laisse pas oublier.
A tester pour voir si sa forme vous convient (ça n'est dit nulle part, mais il est ajustable) : si c'est le cas, et que vous cherchez un casque audiophile éclectique, il n'y a rien en-dessous de 1000 Euros qui touche celui-ci.
Unique
J'ai eu l'ancien modèle et j'ai apprécié ses qualités audio et son confort qui le rendent unique. Dans mon souvenir seul l'AKG K1000 se comportait aussi comme deux petites enceintes.
Je retire 2 étoiles car les mousses sur le dessus du casque et derrière les oreilles se sont délitées au bout de 2 ou 3 ans et comme elles étaient collées, impossible de les changer. J'espère que le constructeur a amélioré le système sur ce nouveau modèle.
article exceptionnel
Livraison rapide, produit conforme, excellent, je connaissais l'ancien modèle, En terme d'ergonomie sans équivalent. Je recommande vivement le marchand et le produit
