By buying this product you get 86 loyalty points
The Ananda-BT R2R are planar magnetic wireless headphones, descended from the Ananda-BT. HiFiMAN is taking advantage of this new version to include their R2R Hymalaya DAC as well as an even thinner nanometric driver membrane and an invisible magnet array, giving this new version a warm, richly detailed sound. The wireless connection uses the Bluetooth 5.1 standard and supports the aptX, aptX HD and LDAC codecs.
For the digital/analogue conversion stage of this new version of the Ananda-BT, HiFiMAN has chosen a Hymalaya R2R ladder resistor network. This 100% analogue conversion method produces a naturally warm sound with a characteristic sonic signature. Moreover, this resistance network is coupled to an FPGA chip that drastically reduces electrical interference between the chip and the surrounding components, resulting in an exceptional signal-to-noise ratio and harmonic distortion rate.
HiFiMAN has taken the opportunity of updating the Anamda-BT to incorporate a diaphragm that is 80% thinner than that of its predecessor. This means that the Anamda-BT responds much faster, while offering an unprecedented level of detail and an incredibly low level of distortion.
The Ananda-BT R2R also stands out for the attention paid to its magnet network. One of the specific features of planar magnetic headphones is the positioning of magnets on both sides of the diaphragm, so the presence of these magnets can interfere with the sound produced by the diaphragm. In response to this problem, HiFiMAN has developed a stealth magnet array that allows sound waves to pass through without generating interference, diffraction or turbulence, resulting in furthermore accurate, broadband sound reproduction.
The Ananda-TD supports the main high-definition Bluetooth transmission protocols, so you can take full advantage of the finesse of audio reproduction. The headphones are compatible with the LDAC, aptX and aptX-HD protocols, so you can enjoy excellent quality even in a wireless configuration.
ANANDA-BT R2R not only supports Bluetooth reception, but can also be connected directly to a device via a USB cable. Depending on the current connection status, Bluetooth/USB mode will be automatically selected as soon as the ANANDA-BT is launched.
Technicals caractheristics
Product type | Wireless headphones |
Headphone type | Open-back |
Headphone format | Circumaural |
Headphone technology | Planar Magnetic |
Headphone connectic | Bluetooth 5.1 USB-C |
Supported Bluetooth codecs | aptX aptX HD LDAC AAC SBC |
Frequency response | 8Hz-55kHz |
Impedance | 25Ω |
Sensitivity | 103dB |
Maximum Bluetooth reception distance | 10m (barrier-free environment) |
Built-in microphone | Yes |
Headphone charging time | 2.7h |
Headphone autonomy | 10h |
Weight | 469g |
Color | Black |
Package | 1x HiFiMAN Ananda-BT R2R 1x Carrying case 1x USB-C to USB-A cable 1x USB-C to USB-C cable |
Color | Black |
Impedance (Ω) | 25 |
Efficiency / Sensitivity (dB) | 103.0 |
Lowest frequency (Hz) | 8 |
Highest frequency (Hz) | 55000 |
Wireless | Yes |
Cable termination | Wireless |
Cable termination | USB-C |
Headphone / Earphone connector | Wireless (Bluetooth) |
