HIFIMAN ARYA UNVEILED Headphones
New
The HIFIMAN Arya Unveiled headphones are open circumaural headphones based on a planar magnetic driver. They benefit from the brand's most advanced technologies, such as a nanometric diaphragm and Stealth Magnet technology, as well as a unique Magnetic Veil design. These features ensure faithful, distortion-free sound reproduction. In addition, its 27 ohms impedance and 94dB sensitivity make these headphones easy to drive. They also boast an extended frequency response of 8Hz-65kHz, for deep bass and rich, detailed mids and highs. In terms of connectivity, it comes with a detachable cable with 6.35mm jack termination.
By buying this product you get 159 loyalty points
Reference : 20501
1 590,00 €tax incl.
1 325,00 € tax excl.
HIFIMAN Arya Unveiled Open-Back Circumaural Planar Magnetic Headphones 27 Ohm 94dB 8Hz-65kHz
Photo du casque HIFIMAN Arya Unveiled
The HIFIMAN Arya Unveiled headphones are open circumaural headphones based on a planar magnetic driver. They benefit from the brand's most advanced technologies, such as a nanometric diaphragm and Stealth Magnet technology, as well as a unique Magnetic Veil design. These features ensure faithful, distortion-free sound reproduction. In addition, its 27 ohms impedance and 94dB sensitivity make these headphones easy to drive. They also boast an extended frequency response of 8Hz-65kHz, for deep bass and rich, detailed mids and highs. In terms of connectivity, it comes with a detachable cable with 6.35mm jack termination. The Arya Unveiled is sure to meet the needs of the most demanding audiophile.
HIFIMAN Arya Unveiled: a revolutionary design
The Audio HIFIMAN Arya Unveiled headphones, as their name suggests, benefit from a bold design that eliminates the grille traditionally found on open-air headphones. The result is an exposed transducer free to express itself fully. This eliminates the effects of sound reflections that can alter the final sound reproduction. The advantage of this design is outstanding audio clarity and transparency.
La conception du casque HIFIMAN Arya Unveiled
HIFIMAN Arya Unveiled: Magnetic Veil technology
The Magnetic Veil technology of the Hifiman Arya Unveiled headphones consists of a removable panel specially designed to protect the earcups, but also as protection against interference that could disturb the nano-diaphragm.
La technologie magnetic veil du casque HIFIMAN Arya Unveiled
Le driver planar magnetic du casque HIFIMAN Arya Unveiled
HIFIMAN Arya Unveiled: high-performance magnetic planar driver
Thanks to its planar magnetic drivers, the Arya Unveiled offers a balanced sound signature and a remarkable transient response. Deep bass and detailed treble deliver a spectacularly rich experience.
HIFIMAN Arya Unveiled: nanometric diaphragm
Arya Unveiled headphones feature an ultra-light diaphragm for fast transient response and a wide dynamic range for natural, clear, richly detailed sound.
Le diaphragme nanométrique du casque HIFIMAN Arya Unveiled
Les aimants furtifs du casque HIFIMAN Arya Unveiled
HIFIMAN Arya Unveiled: stealth magnet
Thanks to their shape and arrangement, stealth magnets allow sound waves to pass through without degradation. This greatly reduces the distortion present in conventional planar magnetic headphone designs.
HIFIMAN Arya Unveiled: comfort and compatibility
The HIFIMAN Arya Unveiled headphones feature an adjustable headband that adapts easily to different body shapes, and comfortable ear cushions for optimum comfort during long listening sessions. In addition, there's a detachable cable configuration with two 3.5mm jack connectors on the headphones for maximum compatibility. Whether for professional use or the expectations of a demanding audiophile, the Arya Unveiled is a first-rate headphone.
Photo du casque audio HIFIMAN Arya Unveiled
Product typeHeadphone
Headphone typeOpen-back circumaural
TransducersPlanar magnetic
Impedance27 Ohms
Sensitivity94dB
Frequency response8Hz - 65kHz
Detachable cable
Headphones connector2x Jack 3.5mm
Weight413g
Package1x HIFIMAN Arya Unveiled
1x Magnetic veils (magnetic protection panels)
1x Detachable 6.35mm jack termination cable
Impedance (Ω)27
Efficiency / Sensitivity (dB)94.0
Lowest frequency (Hz)8
Highest frequency (Hz)65000
WirelessNo
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
HIFIMAN ARYA UNVEILED Open-Back Circumaural Planar Magnetic Headphones 27 Ohm 94dB 8Hz-65kHz
The HIFIMAN Arya Unveiled headphones are open circumaural headphones based on a planar magnetic driver. They benefit from the brand's most...
