HIFIMAN AUDIVINA Headphones
HIFIMAN's Audivina is a planar magnetic circumaural closed-back headphone. The Audivina stands out for its surprisingly open soundstage for closed-back headphones, and the micrometer-thin diaphragm for exceptionally detailed sound reproduction.
By buying this product you get 75 loyalty points
Reference : 20449
759,00 €tax incl.
632,50 € tax excl.
HIFIMAN Audivina Planar Magnetic Close-Back Headphones Cicumaural 20Ω 97dB 5Hz-55kHz
Hifiman Audivina
HIFIMAN Audivina: Resonance chamber
The design of the Audivina's resonance chamber was inspired by the highly respected acoustic architecture of the Bayreuth Festival Theater in Germany, whose multi-level attenuation provides a wide, detailed soundstage in an enclosed space for listeners.
Hifiman Audivina : Resonance chamber
Hifiman Audivina : Membrane
HIFIMAN Audivina: Ultra-thin membrane
The headphones are also distinguished by their diaphragm, which is 80% thinner than the brand's previous diaphragms, with a total thickness of between 1 and 2 micrometers. This enables it to respond more quickly to impulses, while maintaining an exceptional level of detail and extremely low distortion.
HIFIMAN Audivina: Stealth magnet array
Another major feature of the Audivina is its stealth magnet array, designed to minimize the impact of magnets on sound. This network allows sound waves to pass through the magnets without creating interference, diffraction or turbulence, guaranteeing furthermore accurate sound rendering and broadband reproduction.
Hifiman Audivina : Stealth magnet array
Hifiman Audivina : Front view
HIFIMAN Audivina: Also a monitoring headphones
Most headphones use a diffusion field design that can lead to a lack of bass, and are therefore limited to musical listening. However, Audivina's wide frequency response coupled with its very open soundstage and the absence of resonance usually inherent in closed-back headphones make it an ideal candidate for mixing or mastering.
HIFIMAN Audivina: Ergonomics and wearing comfort
When designing Audivina, we also paid particular attention to wearing comfort. The ear cups, for example, are Single-ended to adapt to the natural shape of the ear. Furthermore, the headband has been designed to distribute the weight of the headphones evenly, guaranteeing long listening sessions without the slightest discomfort.
Hifiman Audivina : Inside view of an ear pad
Supplied cables
HIFIMAN Audivina: Supplied cables
To ensure compatibility with all the devices you might want to connect it to, the Audivina comes with a 1.5m cable with 3.5mm jack termination, a 3m cable with 6.35mm jack termination and a 3m cable with XLR termination.
Technicals caractheristics
Product typeHeadphones
Headphone typeClosed-back
Headphone formatCircumaurale
Headphone technologyPlanar Magnetic
Frequency response5Hz-55kHz
Impedance20Ω
Sensitivity97dB
Weight470g
ColorWood
Package1x HIFIMAN Audivina
1x Storage bag
1x Headphone cable 3.5mm jack 1.5m
1x Headphone cable 6.35mm jack 3m
1x Headphone cable XLR 3m
ColorWood
Impedance (Ω)20
Efficiency / Sensitivity (dB)97.0
Lowest frequency (Hz)5
Highest frequency (Hz)55000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationXLR 4-pin
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
HIFIMAN AUDIVINA Headphones Planar Magnetic Closed-Back Cicumaural 20 Ohm 97dB 5Hz-55kHz
HIFIMAN's Audivina is a planar magnetic circumaural closed-back headphone. The Audivina stands out for its surprisingly open soundstage for...
