HIFIMAN DEVA PRO BLUEMINI Headphones
HiFiman Deva Pro Bluemini headphones feature an ultra-thin planar magnetic driver thanks to NsD (“Neo Supernano Diaphragm”) technology. These headphones deliver detailed, clean sound across the entire audible frequency range, yet are easy to drive thanks to their 18-ohm impedance and 94.5dB sensitivity.
By buying this product you get 22 loyalty points
Reference : 20471
229,00 €tax incl.
190,83 € tax excl.
Shipping date: 16-04-2025.
HIFIMAN Deva Pro BlueminiPlanar Magnetic Open-Back Headphones 18 ohm 93.5dB 20Hz-20kHz
Photo du casque HIFIMAN DEVA PRO Bluemini
HIFIMAN Deva Pro Bluemini headphones feature an ultra-thin planar magnetic driver based on NsD (‘Neo Supernano Diaphragm’) technology. Thanks to this advanced design, it delivers detailed, accurate sound across the entire audible spectrum. Its 18Ω impedance and 94.5dB sensitivity guarantee excellent compatibility with a wide range of audio sources.
Lightweight and comfortable, it provides a pleasant listening experience even for long sessions. A detachable cable with TRS jack to 3.5mm jack connectors is included. Whether for sedentary or nomadic use, the HIFIMAN Deva Pro is the perfect everyday ally.
This model is accompanied by the R2R Bluemini DAC, enabling wireless Bluetooth operation with SBC, AAC, aptX, aptX HD and LDAC codecs. Whether you're using it on the move or at home, it offers a listening experience without compromising on sound quality.
HIFIMAN Deva Pro Bluemini : R2R Bluetooth DAC
The HIFIMAN Deva Pro Bluemini headphones come with a Bluetooth R2R DAC for wireless use. It comprises a Qualcomm QCC5124 receiver chip and the brand's proprietary R2R Himalaya DAC. It supports high-resolution Bluetooth codecs: SBC, AAC, aptX, aptX-HD and LDAC. It has USB-C charging port for up to 6-7 hours of autonomy, and simply inserts into the headphones' left earpiece for quick and easy use.
Le spécifications du Bluemini
HIFIMAN Deva Pro Bluemini: A planar magnetic NsD driver
The planar magnetic diaphragm in the HIFIMAN Deva Pro Bluemini headphones features NsD (“Neo Supernano Diaphragm”) technology. This means it's 80% thinner than on the brand's previous designs, for greatly improved transient response, better dynamics and a detailed sound image across its entire frequency range.
Le driver des HIFIMAN DEVA PRO
Les aimants du HIFIMAN DEVA PRO
HIFIMAN Deva Pro Bluemini: Optimal magnet design
The arrangement of the magnets in the HIFIMAN Deva Pro Bluemini headphones limits their impact on sound reproduction. In fact, the magnets are arranged so as to be acoustically transparent to sound waves, enabling clear rendering while reducing the level of distortion.
HIFIMAN Deva Pro Bluemini: Comfortable headphones
Extremely lightweight, HIFIMAN Deva Pro Bluemini headphones are comfortable to wear for long listening sessions. The earcups are wide enough to completely cover the listener's ears, for excellent passive isolation. Moreover, their memory foam adapts perfectly to every morphology.
HIFIMAN DEVA PRO, un casque audio confortable
HIFIMAN Deva Pro Bluemini: A detachable 3.5mm jack cable
HIFIMAN Deva Pro Bluemini headphones feature 3.5mm jack connectors. A 2x jack 3.5mm TRS to jack 3.5mm termination cable is supplied. However, if you prefer a single cable, this can be achieved by connecting a 3.5mm TRRS jack to the left earcup of the headphones.
Please note that Deva Pro Bluemini is not compatible with 3.5mm TS jacks.
La connectique du casque HIFIMAN DEVA PRO
Product typeHeadphone
Heaphone typeOpen-Back
Headphone formatCircumaural
DriverPlanar magnetic (NsD - Neo supernano Diaphragm)
Impedance18 ohm
Sensitivity93.5dB
Frequency response20Hz-20kHz
Headphone connectors2x jack 3.5mm TRS or 1x jack 3.5mm TRRS
Removable cable
Cable terminaisonJack 3.5mm
Bluemini R2R Bluetooth DAC specifications
Bluetooth chipQCC5124
DACHIFIMAN HIMALAYA
SNR114dB
Supported Bluetooth CodecsSBC, AAC, aptX, aptX HD, LDAC
Battery autonomy6-7h
Charging portUSB-C
Weight25g
Weight (headphones)360g
ColorSilver
Package1x HIFIMAN Deva Pro headphones
1x Bluetooth R2R DAC Bluemini
1x Detachable cable 2x jack 3.5mm TRS to termination jack 3.5mm
ColorSilver
Impedance (Ω)18
Efficiency / Sensitivity (dB)93.5
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
HIFIMAN DEVA PRO BLUEMINI Planar Magnetic Open-Back Headphones 18 Ohm 93.5dB 20Hz-20kHz
HiFiman Deva Pro Bluemini headphones feature an ultra-thin planar magnetic driver thanks to NsD (“Neo Supernano...
