HIFIMAN DEVA PRO Headphones
HiFiman Deva Pro headphones feature an ultra-thin planar magnetic driver thanks to NsD (“Neo Supernano Diaphragm”) technology. These headphones deliver detailed, clean sound across the entire audible frequency range, yet are easy to drive thanks to their 18-ohm impedance and 94.5dB sensitivity.
Reference : 20469
185,00 €tax incl.
154,17 € tax excl.
HIFIMAN Deva Pro Planar Magnetic Open-Back Headphones 18 ohm 93.5dB 20Hz-20kHz
Photo du casque HIFIMAN DEVA PRO
HIFIMAN Deva Pro headphones feature an ultra-thin planar magnetic driver thanks to NsD (“Neo Supernano Diaphragm”) technology. These headphones deliver detailed, clean sound across the entire audible frequency range, yet are easy to drive thanks to their 18-ohm impedance and 94.5dB sensitivity. Lightweight and comfortable, it makes for a highly enjoyable listening experience, even for long sessions. A detachable cable with TRS jack connectors to 3.5mm jack termination accompanies the set. Whether for sedentary or nomadic use, the HIFIMAN Deva Pro is the perfect everyday ally.
HIFIMAN Deva Pro: A planar magnetic NsD driver
The planar magnetic diaphragm in the HIFIMAN Deva Pro headphones features NsD (“Neo Supernano Diaphragm”) technology. This means it's 80% thinner than on the brand's previous designs, for greatly improved transient response, better dynamics and a detailed sound image across its entire frequency range.
Le driver des HIFIMAN DEVA PRO
Les aimants du HIFIMAN DEVA PRO
HIFIMAN Deva Pro: Optimal magnet design
The arrangement of the magnets in the HIFIMAN Deva Pro headphones limits their impact on sound reproduction. In fact, the magnets are arranged so as to be acoustically transparent to sound waves, enabling clear rendering while reducing the level of distortion.
HIFIMAN Deva Pro: Comfortable headphones
Extremely lightweight, HIFIMAN Deva Pro headphones are comfortable to wear for long listening sessions. The earcups are wide enough to completely cover the listener's ears, for excellent passive isolation. Moreover, their memory foam adapts perfectly to every morphology.
HIFIMAN DEVA PRO, un casque audio confortable
HIFIMAN Deva Pro: a detachable 3.5mm jack cable
HIFIMAN Deva Pro headphones feature 3.5mm jack connectors. A 2x jack 3.5mm TRS to jack 3.5mm termination cable is supplied. However, if you prefer a single cable, this can be achieved by connecting a 3.5mm TRRS jack to the left earcup of the headphones.
Please note that Deva Pro is not compatible with 3.5mm TS jacks.
La connectique du casque HIFIMAN DEVA PRO
Product typeHeadphone
Heaphone typeOpen-Back
Headphone formatCircumaural
DriverPlanar magnetic (NsD - Neo supernano Diaphragm)
Impedance18 ohm
Sensitivity93.5dB
Frequency response20Hz-20kHz
Headphone connectors2x jack 3.5mm TRS or 1x jack 3.5mm TRRS
Removable cable
Cable terminaisonJack 3.5mm
Weight360g
ColorSilver
Package1x HIFIMAN Deva Pro headphones
1x Detachable cable 2x jack 3.5mm TRS to termination jack 3.5mm
ColorSilver
Impedance (Ω)18
Efficiency / Sensitivity (dB)93.5
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
HIFIMAN DEVA PRO Planar Magnetic Open-Back Headphones 18 Ohm 93.5dB 20Hz-20kHz
HiFiman Deva Pro headphones feature an ultra-thin planar magnetic driver thanks to NsD (“Neo Supernano Diaphragm”) technology....
