HIFIMAN HE-R10D BLUEMINI Headphones
The HIFIMAN HE-R10D Bluemini is a pair of dynamic circumaural closed-back headphones featuring no less than 50mm dynamic transducers.
By buying this product you get 36 loyalty points
Reference : 20477
369,00 €tax incl.
307,50 € tax excl.
HIFIMAN HE-R10D BlueminiCasque Audio Dynamique Fermé Circumaural Bluetooth 5.0 aptX HD LDAC
Photo of HifiMan HE-R10D Bluemini
The HIFIMAN HE-R10D Bluemini are dynamic closed-back circumaural headphones featuring powerful 50mm drivers. These transducers are combined with finely machined wooden shells, which form an optimised acoustic cavity, allowing detailed sound reproduction and a surprisingly wide soundstage for a closed model. With an impedance of 60Ω and a sensitivity of 103dB, it's relatively easy to drive. To ensure maximum compatibility, three cables with 3.5mm TRS jack connectors and different terminations are supplied. The HE-R10D is accompanied here by the Bluemini R2R Bluetooth 5.0 DAC, supporting Bluetooth wireless transmission and the SBC, AAC, aptX, aptX-HD and LDAC codecs.
The frequency response of the HifiMan HE-R10D
HIFIMAN HE-R10D Bluemini: R2R Bluetooth DAC
The HIFIMAN HE-R10D Bluemini headphones come with an R2R Bluetooth DAC for wireless use. It comprises a Qualcomm QCC5124 receiver chip and the brand's proprietary R2R Himalaya DAC. It supports high-resolution Bluetooth codecs: SBC, AAC, aptX, aptX-HD and LDAC. It recharges via USB-C for up to 6-7 hours' autonomy, and simply inserts into the headphones' left earcup for quick and easy use.
DAC R2R Bluetooth 5.0 Bluemini overview
HIFIMAN HE-R10D Bluemini: A Ø50mm diaphragm
The HE-R10D Bluemini's diaphragm uses a technology consisting of nanoparticles applied to target areas of the diaphragm to optimize its properties for better performance. The brand also uses high-sensitivity magnets for greater dynamics across the entire frequency range from 15Hz to 35kHz.
The diaphragm of the HIFIMAN HE-R10D headphones
The wooden shell of the HIFIMAN HE-R10D
HIFIMAN HE-R10D Bluemini: A CNC-machined wooden shell
The HE-R10D Bluemini's CNC-machined wood shell is large enough to provide adequate breathing space for the headphones' powerful 50mm diaphragm. In addition, the selected wood has unique acoustic properties. This wood shell offers an acoustic cavity that helps suppress unwanted resonances while providing a wide soundstage despite the headphones' closed design. Overall sound reproduction is also more natural and clear.
HIFIMAN HE-R10D Bluemini: Comfortable headphones
Ideal for long listening sessions thanks to its large earcups and adjustable headband, the HIFIMAN HE-R10D Bluemini headphones adapt to a wide range of head shapes. The earcups and headband are padded for optimum wearing comfort and weight distribution.
Photo of Hifiman HE-R10D headphones
Product typeHeadphones
Headphone typeClosed-back circumaural
TransducerDynamic
Transducer diameterØ50mm
Impedance60 ohm
Sensitivity103dB
Frequency response15Hz-35kHz
Spécification du Bluemini
Bluetooth chipQCC5124
DACR2R HIMALAYA
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
SNR114dB
Frequency response20Hz-20kHz
CHarging portUSB-C
Battery autonomy6-7h
Weight25g
Weight (headphones)360g
ColorWood
Package1x HIFIMAN HE-R10D headphones
1x DAC R2R Bluetooth Bluemini
1x Cable jack 3.5mm TRS to termination jack 3.5mm (1.5m)
1x 3.5mm TRS jack cable to 6.35mm jack termination (3m)
1x 3.5mm TRS jack cable to XLR termination (3m)
ColorWood
Impedance (Ω)60
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)15
Highest frequency (Hz)35000
WirelessYes
Cable terminationJack 3.5mm
Cable terminationXLR 4-pin
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
HIFIMAN HE-R10D BLUEMINI Closed Dynamic Circumaural Headphones Bluetooth 5.0 aptX HD LDAC
