HIFIMAN HE-R9 Wired Closed Back Headphone Dynamic Transducers 32Ω 100dB 15Hz-35kHz
The HIFIMAN HE-R9 headphones feature a unique closed circumaural configuration designed to deliver immersive and detailed sound through optimized acoustics. The headphones feature a pair of large, dynamic drivers using the brand's Topology Diaphragm technology, revealing a wide soundstage and incredible fidelity.
Reference : 16417
99,00 €tax incl.
82,50 € tax excl.
HIFIMAN HE-R9
Circumaural Closed Back Headphone Dynamic Transducers 32Ω 100dB 15Hz-35kHz
HIFIMAN HE-R9 Casque Audio Circumaural Fermé Transducteurs Dynamiques 32Ω 100dB 15Hz-35kHz
HIFIMAN Topology Diaphragm
The HE-R9 uses the Topology Diaphragm technology developed by HIFIMAN. It consists of a membrane covered with nanoparticles on the surface to improve its mechanical properties. This design offers a natural and detailed sound reproduction over a wide frequency range, from 15Hz to 35kHz.
In addition, the low impedance (32Ω) and high sensitivity (100dB/mW) allows the HE-R9 to be easily powered by a smartphone, DAP or a sedentary headphone amplifier as well.
A unique design
With its impressive shells, the HE-R9 manages to create a large internal space for the acoustic chamber where the transducer is placed, allowing the transducer to express itself without constraint. This structure makes the headphones capable of delivering a beautiful sound image. In addition, the closed structure of the headphones ensures excellent isolation from and to the outside world, so you can enjoy your music to the fullest.
Despite its impressive form factor, the HE-R9 maintains a contained weight of only 328g. Combined with large ear cups and a generously padded headband, HIFIMAN's headphones offer undeniable listening comfort, even over long periods of time.
Dual connectors
Each headset of the HE-R9 is equipped with a 3.5mm jack connector to which the supplied Y-cable can be connected. The cable also terminates in a 3.5mm stereo jack and comes with a 3.5mm jack to 6.35mm jack adapter.
Particularity of this HE-R9, it is also possible to use a unilateral cable, the connector of the left auricle being in stereo TRRS format. It is thus able to make transit the signal of the right channel towards the right auricle, thanks to an internal cable within the arch.
Product typeHeadphone
Headphone typeCircumaural
ConceptionClosed back
Drivers typeDynamic
DiaphragmTopology Diaphragm - Nanoparticle coated diaphragm
Frequency response15Hz - 35kHz
Impedance32Ω
Sensitivity100dB
Weight328g
Package1x HIFIMAN HE-R9
1x Stereo Jack 3.5mm to 2x Jack 3.5mm mono cable 1.5m
ColorBrown
Impedance (Ω)32
Efficiency / Sensitivity (dB)100.0
Lowest frequency (Hz)15
Highest frequency (Hz)35000
WirelessNo
The HIFIMAN HE-R9 headphones feature a unique closed circumaural configuration designed to deliver immersive and detailed sound through optimized...
