HIFIMAN ISVARNA Headphones
HIFIMAN Isvarna headphones are high-end closed-back circumaural headphones featuring a hybrid design with a planar magnetic and dynamic driver. This design offers outstanding capabilities over a very wide soundstage from 6Hz to 60kHz. Stealth Magnet technology, coupled with a nanometric diaphragm, ensures superb transient response.
By buying this product you get 319 loyalty points
Reference : 20499
3 190,00 €tax incl.
2 658,33 € tax excl.
HIFIMAN Isvarna Closed-Back Hybrid Planar Magnetic Dynamic Headphones 16 ohm 93dB 6Hz-60kHz
Photo of HIFIMAN Isvarna headphones
When it comes to isolation, it's the closed design that facilitates an immersive experience. In terms of ergonomics and aesthetics, comfort and sophistication are the two components that ensure long listening sessions in complete tranquillity. Add to this a 16 ohm impedance, 93dB sensitivity and 3 interchangeable cables with 3 different terminations (XLR 4 pins, jack 6.35mm and jack 3.5mm) for an excellent level of compatibility. These headphones are ideal for demanding audiophiles.
HIFIMAN Isvarna: A hybrid design
HIFIMAN Isvarna headphones feature a hybrid design with a planar magnetic transducer combined with a dynamic driver per earpiece. The planar magnetic transducer handles high frequencies for clear, precise reproduction, while the dynamic driver handles low frequencies. This top-of-the-range design offers a perfect balance in the reproduction of different frequencies, for an immersive and deep overall sound reproduction that is no less detailed. HiFiman's secret lies in the use of a custom filter circuit that allows these two different technologies to be used in harmony.
The design of the HIFIMAN Isvarna headphones
HIFIMAN Isvarna: Stealth magnet technology
The arrangement of the magnets in the design of the HIFIMAN Isvarna headphones limits their impact on sound reproduction. In fact, the magnets are arranged in such a way as to be acoustically transparent to the sound waves, enabling clear rendering while reducing the level of distortion.
HIFIMAN Isvarna headphones magnets
The diaphragm of HIFIMAN Isvarna headphones
HIFIMAN Isvarna: Nanometric diaphragm
The ultra-lightweight diaphragm of Isvarna headphones gives them fast transient response and a wide dynamic range for natural, clear, richly detailed sound.
HIFIMAN Isvarna: Optimum compatibility
HIFIMAN Isvarna headphones come with three different cables for optimum compatibility right from the start. There's a balanced XLR 4-pin cable, a 6.35mm jack cable and a 3.5mm jack cable.
The compatibility of HIFIMAN Isvarna headphones
HIFIMAN Isvarna: Comfortable headphones
HIFIMAN  Isvarna audio headphones combine comfort and aesthetics for a pleasant listening experience. They feature an adjustable metal headband to suit every body shape, and soft, comfortable ear pads for long listening sessions. The whole set is made with top-of-the-range materials for elegance and functionality.
Product typeHybrid headphones
Headphones typeClosed-Back Circumaural
TransducersDynamic
Planar magnetic
Impedance16 Ohms
Sensitivity93dB
Frequency response6Hz-60kHz
Detachable cable
Headphone connector2x jack 3.5mm
Weight462g
Package1x HIFIMAN Isvarna
1x Detachable 3.5mm jack termination cable, angled (1.5m)
1x Detachable 6.35mm jack termination cable (3m)
1x Detachable balanced XLR 4-pin termination cable (3m)
ColorSilver
Impedance (Ω)16
Efficiency / Sensitivity (dB)93.0
Lowest frequency (Hz)6
Highest frequency (Hz)60000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Cable terminationXLR 4-pin
Headphone / Earphone connectorJack 3.5mm
HIFIMAN ISVARNA Closed-Back Hybrid Planar Magnetic Dynamic Headphones 16 Ohm 93dB 6Hz-60kHz
HIFIMAN Isvarna headphones are high-end closed-back circumaural headphones featuring a hybrid design with a planar magnetic and dynamic driver....
