HIFIMAN MINI SHANGRI-LA Headphones
Hifiman's Mini Shangri-La are carefully designed electrostatic headphones. Electrostatic technology coupled with a nanometric membrane means you can count on a level of sound reproduction of rare quality, so you can enjoy your tracks in every detail.
By buying this product you get 122 loyalty points
Reference : 19421
1 229,00 €tax incl.
1 024,17 € tax excl.
Shipping date: 22-04-2025.
Hifiman Mini Shangri-La Electrostatic Open-Back Headphones 7Hz-90kHz
Hifiman Mini Shangri-La : Front view
HiFiMAN's Mini Shangri-La are carefully designed electrostatic headphones. Electrostatic technology coupled with a nanometric membrane means you can count on a level of sound reproduction of rare quality, so you can enjoy your tracks in every detail.
HiFiMAN Mini Shangri-La : Electrostatic headphones
The Mini Shangri-La headphones feature an electrostatic driver design. The basic principle of this technology is to place a static electric charge on a membrane floating between two perforated metal plates. When an electrical voltage is applied to the plates, the adhesion and repulsion of the static electricity causes the membrane to vibrate without direct physical contact. The advantage of this system is that the membrane produces a perfectly uniform sound signal, greatly reducing the diffraction of sound and therefore enabling sound reproduction of staggering fidelity. It should be noted, however, that electrostatic headphones require a specially dedicated amplifier because of the voltage of several hundred volts needed to operate them.
Hifiman Mini Shangri-La : close-up of an earpiece
HiFiMAN Mini Shangri-La : A nanometric membrane
HiFiMAN's Mini Shangri-La headphones have a membrane only a few nanometres thin. This technical feat increases the bandwidth beyond the audible spectrum (7hz to 90,000hz), extending the bandwidth to reveal the last primordial octaves of your favourite recordings, revealing a wealth of previously unknown detail.
HiFiMAN Mini Shangri-La : Double protection
HiFiMAN has decided to apply two types of protection to the outside of its earpieces. Firstly, a nanometre-thin layer prevents dust or any other pollutant from infiltrating the inside of the headphones and causing distortion. The second protection takes the form of a honeycomb grid, which protects the driver from airflow vibrations, guaranteeing faithful, accurate sound reproduction.
Hifiman Mini Shangri-La : External view of an earpiece
Technicals caractheristics
Product typeHeadphone
Headphone typeOpen back
Headphone formatCircumaurale
Headphone technologyElectrostatic
Headphone connectic5-pins electrostatic connector
Frequency response7Hz - 90kHz
Bias Voltage550V-650V
Weight320g
ColorSilver
Conditionnement1x Headphones Hifiman Mini Shangri-La
ColorSilver
Impedance (Ω)NC
Lowest frequency (Hz)7
Highest frequency (Hz)90000
WirelessNo
Cable termination5-pin connector
Headphone / Earphone connectorNon-detachable cable
HIFIMAN MINI SHANGRI-LA Electrostatic Open-Back Headphones 7Hz-90kHz
Hifiman's Mini Shangri-La are carefully designed electrostatic headphones. Electrostatic technology coupled with a nanometric membrane means...
