By buying this product you get 670 loyalty points
Orthodynamic Helmet - Ultra Fins Drivers
Orthodynamic (or isodynamic) technology uses a different process to maintain and vibrate the membrane, producing the sound wave. Thus, the diaphragm is traversed by very fine conductors and surrounded by two flat magnets. When the current passes through the conductors, the magnetic field of the conductors interacts with that generated by the magnets, causing the diaphragm to vibrate at a very high rate and in a consistent and uniform manner. Thanks to this method, the sound reproduction of the helmet takes a whole new dimension.
The drivers of the helmet are extremely thin, less than a millionth of a meter and have a very low mass. They therefore produce very low distortion and excellent dynamics.
By combining this diaphragm and Stealth Magnet technology in harmony, the Susvara delivers audio quality that reaches peaks and clarity.
The design of the Susvara has been painstakingly thought out optimized to avoid resonant frequencies and allowing great sound purity. It also offers effective protection of the diaphragm and of course a licking aesthetics.
The helmet offers comfort that will allow you to wear it during long hours of listening./ P>
Technology | Orthodynamique |
Frequency Response | 6Hz - 75kHz |
impedance | 60 Ohms |
<sensitivity/ Td> | 83dB |
Weight | 450g |
Color | Walnut |
Color | Silver |
Impedance (Ω) | 60 |
Efficiency / Sensitivity (dB) | 83.0 |
Lowest frequency (Hz) | 6 |
Highest frequency (Hz) | 75000 |
Wireless | No |
Cable termination | Jack 6.35mm |
Cable termination | XLR 4-pin |
Headphone / Earphone connector | Jack 3.5mm |
