Thank you Audiophonics for all your support!!
By buying this product you get 99 loyalty points
The KINGSOUND KS-H4 is the nomadic evolution expected of the famous firm that will allow you to enjoy the best of the world of electrostatic music in roaming.
Particularly compact and lightweight, it is equipped with rotating axes at 90 ° for space saving and ease of use and the cable is independent of the helmet.
Havensi, it fits elegantly in its carrying pouch with a dedicated slot to accommodate the KINGSOUND M-03 amplifier and ESL extension cable.
Impricocheting with accuracy and clarity, he shows himself audacious at the top of the spectrum and very balanced in the low mediums.
He is also at ease to transcribe electronic music on an acoustic instrumental or a cappella singing.
A real revolution in listening to the headphones at this price, it will offer you the sound reproduction of a classic amplifier system and speakers to several tens of thousands of euros.
You will not listen to a simple headphone but music in the best possible conditions of reproduction to date thanks to an exceptional technology.
How does it work?/ Em>
The electrostatic loudspeaker is a simple concept, but difficult to implement successfully in practice.
The operation is based on the electrostatic attraction of the sameso that a piece of paper is attracted by a friction balloon.
The ultra-thin membrane, electrically charged, is stretched and placed between two metal grids.
When a high voltage audio signal is applied to the metal grids, the diaphragm moves to the grid in response to the signal.
At this moment, it has an opposite charge and is away from the gate which has the same charge as the membrane.
The diaphragm reacts linearly, producing sound waves that reproduce very precisely the original sound.
Why is it better?
Imagine a normal loudspeaker from which the sound waves diffract over a wide angle. This causes a rapid decrease in volume and sound quality.The electrostatic stereo system is the ultimate in audio reproduction.
A professional listening system with minimal distortion. It literally pushes the limits of the most sophisticated instruments in the world that try to measure its performance.
This is an experience that few stereo systems can approach.
The result is awide frequency range over the range that others can not afford.
Specifications:
Physical characteristics:
The electrostatic headphonesthat Kingsound KSH4 received the highest distinction 2016
the coveted Audio Excellence Award
Illustration with a KINGSOUND M-03 portable amplifier (not supplied).
Illustration of the M-03 in its case, placed in the dedicated housing.
Color | Silver |
Impedance (Ω) | 115 |
Efficiency / Sensitivity (dB) | 106.0 |
Lowest frequency (Hz) | 6 |
Highest frequency (Hz) | 42000 |
Wireless | No |
Cable termination | 5-pin connector |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
