Très belle association, précision du son , limpidité, présence, texture, bref que demander de plus?
By buying this product you get 149 loyalty points
How does it works ?
The electrostatic loudspeaker is very simple in concept, but difficult to construct successfully in practice.
lts operation relies on electrostatic attraction and repulsion, in much the same way as a piece of thin paper attracted to a rubber balloon that is charged by rubbing it against fabric.
The electrically charged ultra-thin conductive film diaphragm is tensioned and placed close between two metal grids.
When a high voltage audio signal is applied to the metal grids, the diaphragm moves in response to the signal, moving towards the grid which at that instant is oppositely charged, and away from the grid which has the same charge as the diaphragm.
The diaphragm responds in an essentially linear manner, producing sound waves which are a very accurate reproduction of the original sound.
Why is it better ?
Imagine a normal speaker as a point source, from which the sound waves produced diffract at a great angle. This causes rapid decrease in volume and quality over a short distance.
Then imagine a flat electrostatic panel producing sound from the same input signal. This time the sound waves are produced over a large, flat area, therefore have very little diffraction and the volume decreases much less over the same distance.
The electrostatic stereo system is the pinnacle of audio reproduction. The standard upon which all other stereo headphones can be measured.
It literally pushes the limits of the world's most sophisticated instruments that attempt to measure its performance.
The result is an experience that no other stereo system can approach.
The result is an ultra-flat frequency response across the entire range: deep, clean bass with real power that other attempts at electrostatic transducers can only envy.
Le KINGSOUND KS-H4 est l'évolution nomade attendue de la célèbre firme qui vous permettra de profiter du meilleur du monde de la musique électrostatique en itinérance.
Particulièrement compact et léger, il est équipé d'axes rotatif à 90° pour un gain de place et un confort d'utilisation et le câble est indépendant du casque.
Ainsi, il s'intègre avec élégance dans sa pochette de transport disposant d'un emplacement dédié à loger la rallonge de câble ESL.
Impressionnant de justesse et de clarté, il se montre audacieux dans le haut du spectre et très équilibré dans les bas médium.
Il se révèle aussi à l'aise pour retranscrire de la musique électronique que sur une instrumentale acoustique ou un chant a capella.
Véritable révolution de l'écoute au casque à ce prix, il vous offrira la restitution sonore d'un système classique amplificateur et enceintes à plusieurs dizaines de milliers d'euros.
Vous n'écouterez plus un simple casque mais de la musique dans les meilleures conditions de restitution possibles à ce jour grâce à une technologie exceptionnelle.
Le KINGSOUND M-10 est un amplificateur à transistor puissant et robuste au design épuré.
Le Pack KINGSOUND M-10 & KS-H4 est un couple au rapport qualité prix très intéressant qui vous permettra d'apprécier le meilleur du monde de la musique électrostatique avec une grande qualité de restitution.
L'amplificateur M-10 est même compatible avec les casques des autres marques proposant cette technologie.
Spécialement conçu pour sublimer les casques de la marque pour lesquels il a été conçu, ce magnifique amplificateur vous permettra non seulement de tirer le meilleur parti des KS-H2, KS-H3 et KS-H4 mais aussi des casques d'une célèbre marque japonaise utilisant la même technologie.
Il est la réponse cohérente pour driver avec dynamique, autorité, et finesse les membranes électrostatique de votre casque KINGSOUND KS-H4.
Caractéristiques du KS-H4 :
Caractéristiques du M-10 :
Support casque non fourni.
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
