KIWI EARS DIVISION Headphones Black
New
Kiwi Ears Division headphones combine high-quality sound with modern styling. Featuring dynamic 40mm drivers, they deliver balanced bass, neutral mids and clear highs. Lightweight and featuring leatherette-covered ear cushions, Kiwi Ears Division guarantee on-the-go listening comfort with excellent sound performance.
Reference : 20601
49,90 €tax incl.
41,58 € tax excl.
Kiwi Ears Division Headphones Dynamic Closed-Back Ø40mm 32 Ohm Black
Photo of Kiwi Ears Division headphones
Kiwi Ears headphones have been designed as monitoring headphones. It is therefore focused on professional tuning and has a fairly neutral tonal signature.
Kiwi Ears Division: 40mm dynamic drivers
The Kiwi Ears Division uses a large 40mm dynamic driver with composite cone for each earpiece. Based on a proven design, the Division's dynamic driver is powerful and precise. Diaphragm tension is adjusted after extensive testing to ensure optimum responsiveness. The voice coil and magnets have also been improved for a richer sound.
Kiwi Ears Division: Professional tuning
The Division is professionally calibrated to deliver transparent reproduction, with punchy bass, neutral mids and detailed highs. The tonal balance of Kiwi Ears Division headphones is designed for precision. Bass has deep impact and rapid decay, guaranteeing a clean, defined sound. Mids remain neutral for precise reference of instruments and vocals, while highs are exceptionally clear and detailed, underlining every nuance without harshness.
Kiwi Ears Division: Classic sound, modern style
Kiwi Ears Division combines classic sound with modern design. Its lightweight structure and comfortable, leatherette-covered earpads make it ideal for use on the move.
Kiwi Ears Division: Wired headphones
The Kiwi Ears Division is a wired headphones designed to deliver excellent sound quality. It therefore comes with a detachable cable with 3.5mm jack termination, as well as a 6.35mm jack adapter.
Product typeHeadphones
Headphones typeClosed-back
DriversDynamic Ø40mm
Impedance32Ω
Sensitivity98dB +/-3dB
Detachable cableYes
Cable terminationJack 3.5mm (6.35mm jack adapter included)
Package1x Kiwi Ears Division
1x Jack 3.5mm cable
1x Jack 6.35mm adapter
Impedance (Ω)32
Efficiency / Sensitivity (dB)98.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Headphone / Earphone connectorJack 3.5mm
Noise reductionNo
KIWI EARS DIVISION Headphones Dynamic Closed-Back Ø40mm 32 Ohm Black
Kiwi Ears Division headphones combine high-quality sound with modern styling. Featuring dynamic 40mm drivers, they deliver balanced bass, neutral...
