LINDY LH500XW Wireless Headphone Active Noise Cancellation ANC Bluetooth 4.1 aptX LL 20Hz-20kHz
The Lindy LH500XW is a high-performance active noise cancelling headphone with Bluetooth 4.1 wireless connectivity, supporting the high-resolution aptX transmission codec. The headphones are battery operated and have a comfortable 15-hour battery life. The 40mm neodymium drivers ensure a balanced sound reproduction with clear highs and deep lows.
Reference : 15860
115,00 €tax incl.
95,83 € tax excl.
Lindy LH500XW
Lindy LH500XW Casque Audio Sans-Fil Reduction de Bruit Active ANC Bluetooth 4.1 AptX LL 20Hz-20kHz
The headphone can also be used in wired mode, especially for long listening sessions without worrying about the battery level, thanks to the 3.5mm jack cable provided.
The LH500XW incorporates an active noise-cancellation function to block out ambient noise. This technology reduces external noise by 85%, making it suitable for use in noisy environments.
The headphone's leatherette ear cushions provide excellent comfort and the adjustable headband allows for effective adjustment to fit all body types.
The LH500XW also has built-in controls for easy and convenient management of your music playback and volume level. The on-board microphone makes it easy to answer your phone calls, and the controls allow you to act on the current call.
The headphone's Lithium battery can be recharged quickly, in just 3-4 hours for a full charge, providing up to 15 hours of playback.
Product typeHeadphone
DesignCircum-aural
Speaker driversNeodymium 40mm
ConnectivityInput : Jack 3.5mm
Power supply : Micro USB
Active Noise Cancellation (ANC)85% reduction in low frequency noise
Bluetooth version4.1
Bluetooth chipCSR8645
BatteryLithium
Battery lifeANC only : 30h
Wirelle only : 15h
ANC + Wireless : 12h
ImpedancePassive mode : 32Ω
ANC mode : 100Ω
Sensitivity (1mW @ 1kHz ±3dB)Passive : 93dB
ANC : 103dB
Bass : 104dB
Frequency response20Hz-20kHz
THDPassive : < 0.1% @ 1kHz
Active : < 0.5% @ 1kHz
Supported Bluetooth codecsaptX, aptX LL
Hands-free calling function
Dimensions196 x 160 x 45mm
Shell materialPlastic
Weight198g
Operating temperature-10°C / 50°C
Storage temperature-10°C / 50°C
Relative humidity25% - 70% RH (no condensation)
CertificationCE, FCC, RoHS, REACH
Package1x Lindy LH500XW
1x Jack 3.5mm 1.5m cable
1x USB-A to Micro USB 0.8m cable
1x Jack 6.35mm adapter
1x Airplane adapter
1x EVA hard shell carrying case
Impedance (Ω)32
Impedance (Ω)100
Efficiency / Sensitivity (dB)104.0
Efficiency / Sensitivity (dB)93.0
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorWireless (Bluetooth)
Headphone / Earphone connectorJack 3.5mm
The Lindy LH500XW is a high-performance active noise cancelling headphone with Bluetooth 4.1 wireless connectivity, supporting the high-resolution...
