LINDY LH900XW Wireless Headphone Active Noise Cancellation ANC Bluetooth 5.0 aptX HD 20Hz-20kHz
The LH900XW headphones are the highest-end model in the Lindy headphone lineup. As such, it offers superior audio performance with hybrid noise cancellation technology and fast charging via USB-C. Its extensive features deliver a high-quality listening experience, with deep bass, lively mids and crystal clear highs.
Reference : 15862
145,00 €tax incl.
120,83 € tax excl.
Lindy LH900XW
Lindy LH900XW Casque Audio Sans-Fil Réduction de Bruit Active ANC Bluetooth 5.0 aptX HD 20Hz-20kHz
The LH900XW's Hybrid Noise Cancellation (ANC) technology uses noise-sensing microphones, placed both outside the listening area (feedforward) and inside it (feedback). This technology allows a suppression of the noise which can reach 95% for a comfortable listening, even in noisy environments. Moreover, a mode allows not to cancel completely the external noise and thus to be able to remain attentive to its environment.
When the headphones are removed, discreetly placed sensors interrupt your music playback, which resumes automatically once the headphones are back in place.
The LH900XW is equipped with a rechargeable battery ensuring a 15 hours autonomy in wireless reading. A wired connection is also possible using the supplied 3.5mm jack cable. The headphone is charged via a USB-C connector. Its charge level is displayed using a series of LEDs or on the screen of the associated device (if compatible).
Finally, the large leatherette earpads and adjustable headband ensure optimal fit and comfort, even during long listening sessions.
Product typeHeadphone
Headphone designCircum-aural
Speaker driver40mm Neodymium
ConnectivityInput : Jack 3.5mm
Power connector : USB-C
Active noise cancellation (ANC)95% reduction of low frequency noise
Bluetooth version5.0
Bluetooth chipCSR8670
Supported Bluetooth codecsaptX, aptX HD
BatteryLithium
Battery lifeANC only : 30h
Wireless only : 15h
ANC + Wireless : 12h
ImpedancePassive mode : 32Ω
ANC mode : 100Ω
Sensitivity (1mW @ 1kHz ±3dB)Passive : 93dB
ANC : 95dB
Frequency response20Hz-20kHz
THDPassive : < 0.5% @ 1kHz
Active : < 0.5% @ 1kHz
Other featuresExternal audio pass-through
Auto-Pause technology
Dual pairing
Hands-free calling function
Dimensions200 x 210 x 50mm
Shell materialPlastic
Weight914g
Température de fonctionnement-25°C / 50°C
Température de stockage-25°C / 50°C
Humidité relative35% - 80% RH (sans condensation)
NormesCE, FCC, RoHS, REACH
Package1x Lindy LH900XW
1x Câble Jack 3.5mm 1.5m
1x Câble USB-A vers USB-C 0.8m
1x Adaptateur Jack 6.35mm
1x Adaptateur avion
1x Étui de transport EVA rigide
Impedance (Ω)100
Impedance (Ω)32
Efficiency / Sensitivity (dB)93.0
Efficiency / Sensitivity (dB)95.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorWireless (Bluetooth)
Headphone / Earphone connectorJack 3.5mm
The LH900XW headphones are the highest-end model in the Lindy headphone lineup. As such, it offers superior audio performance with hybrid noise...
