MEZE 99 NEO Portable High Fidelity Headphone 26 Ohm 103dB
The Meze 99 Neo audiophile mobile headphones redefine the very term price/performance ratio, offering headphones with contemporary curves and premium sound quality. The revelation of the year 2016/2017 for amateurs who want aesthetics and musical quality.
4.6 / 5
Reference : 12084
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 22-04-2025.
Meze 99 Neo
Meze 99 Neo Casque Haute Fidélité Nomade 103dB
It is a closed model with real acoustic qualities. Easy to power thanks to its low impedance of 26 Ohm, it will be as comfortable with a smartphone with a low output level as it is with an audiophile HiFi headphone amplifier.
The Meze 99 Classics differs from the Meze 99 Classics not only in its slightly modified transducers for a more incisive sound, but also in its design, which here integrates plastic shells.
The headphone is completely assembled on silicone suspensions without any glue, only by noble mechanical parts made of steel alloy, zinc and manganese in low resonance ABS shells.
This headphone's double-headband system, ABS shells and weight of only 260g allow long hours of listening without fatigue.
A stylish and comfortable helmet
The Meze 99 Neo benefits from a perfectly studied design and an extremely meticulous construction. The shells are precisely machined to accommodate each component of the helmet, and treated to provide a beautiful finish. They are mounted on a thin, flexible headband made of a steel, zinc and manganese alloy, to which the self-adjusting headband is attached. The headband is covered in synthetic leather and guarantees maximum comfort. The ear cushions are made of shape memory foam, covered with the same imitation leather as the headband, and perfectly surround the ears without constraining them, helping to effectively isolate the listener from the surrounding noise.
A design thought for a restitution out of the ordinary
Each headset headset includes a dynamic transducer with a diameter of Ø40mm, offering a balanced response curve from 15Hz to 25kHz. The result is a warm and extremely accurate sound reproduction. With an impedance of only 26 Ohm and a sensitivity of 103dB (@ 1kHz, 1mW), the Meze 99 Neo can easily be powered by a smartphone, tablet, and of course a DAP or headphone amplifier. Despite the closed design, the headphones are easy to use and provide a beautiful sound stage.
Meze 99 Neo Casque Haute Fidélité Nomade 103dB Meze 99 Neo Casque Haute Fidélité Nomade 103dB
HiFi & Portable
The Meze 99 Neo is designed for both sedentary use with a stereo amplifier or home audio system, as well as nomadic use. The Meze 99 Neo is delivered with a Y-shaped cable, including a microphone and made of OFC copper conductors with a Kevlar-reinforced jacket. The headset is delivered with a nice semi-rigid case to store and protect the headset properly. An accessory pack including a 3.5mm to 6.35mm jack adapter, a pocket for accessories and the additional cable is also provided.
Product typeAudio headphone
Headphone typeClosed
CouplingCircumaural
Drivers typeDynamic
Drivers diameterØ40mm
EarpadsMedium density shape memory foam, leatherette covered
Self-adjusting headband
ArceauSteel, zinc and manganese alloy
HullsPlastic
AssemblyWithout glue, only with screws
Frequency response15Hz - 25kHz
Sensitivity103dB @ 1kHz, 1mW
Impedance26 Ohm
Power handlingRMS : 30mW
Max : 50mW
Cable conductorsOFC Copper
Cable sheathKevlar reinforced
Cable connectorsGold plated Jack 3.5mm
Dimensions170 x 205 x 85mm
Weight260g
Package1x Meze 99 Neo headphone
1x Carrying case
1x Accessory pouch
1x Cable
1x Telephone cable with microphone 1.2m
1x Jack 3.5 to Jack 6.35mm adapter
Impedance (Ω)26
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)15
Highest frequency (Hz)25000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
5 reviews
Très belle surprise, pour une superbe écoute
Un grand merci à l'équipe d'AUDIOPHONICS, pour leur services en général, leurs conseils, réactivité, sincérité, ont fait, que je n'ai nullement réfléchi sur le choix de ce casque, et je ne suis pas déçu, bien au contraire! Très belle surprise, pour une superbe écoute, dès les premières notes perçues, sincèrement pourquoi mettre plus chère,alors que tout est là ou presque!
Musicalement, Richard.
This review has been posted for MEZE 99 NEO Portable High Fidelity Headphone 26 Ohm 103dB
Super casque mais pas le plus confortable
Globalement très content de mon achat.
La sonorité est très agréable même si le côté étriqué des voix m'a d'abord un peu rebuté comparé à mon Sennheiser HD660S qui lui est ouvert. Par contre le timbre des voix est particulièrement agréable !
Niveau esthétique je le trouve vraiment très beau.
Par contre le confort est loin d'être parfait. Rien à dire du côté de l'arceau et du système de réglage automatique mais j'ai beau avoir une petite tête, mes oreilles touchent en permanence à cause d'une profondeur trop faible des coussinets ce qui rend l'utilisation du casque douloureuse après quelque temps.
J'ai l'impression que je m'y suis un peu habitué mais j'ai quand même commandé des coussinets plus épais en espérant que le son et l'esthétique ne soient pas trop dénaturés.
Casque nomade ... mais haut de gamme
J'ai fait sa critique sur un autre produit qui lui va comme un gant : Le DAC E1DA.
Je recommande les deux.
J'ai un casque Focal et ShennHeiser, je vais les offrir à mes neveux. Mezze only !!!
Absolument superbe !
Attendu des semaines mais Audiophonics n'y est pour rien... Il est arrivé il y a 2 jours et je ne le quitte plus.
Je suis pas d'accord avec le commentaire précédent pour lequel les basses sont trop présentes. Loin s'en faut elles sont très basses, concises et précises, jamais agressives et baveuses et pourtant mon écoute des basses sur des casques comme le H800S ou le Sony MR-Z1R est plus qu'aboutie !
Non seulement les registres sont bien là mais la dynamique et la spatialisation sont présentes et bluffantes pour un "petit" casque (qui a tout l'air d'un grand).
Les aigus peuvent déranger car très hauts au départ mais après une quinzaine d'heures de chauffe, cela disparait.
Ah oui j'écoute avec le câble symétrique en 4.4 de Meze, ce qui fait nettement la différence d'avec le câble asymétrique d'origine sur un Fiio M15.
Vraiment un très grand produit de Meze à "petit" prix pour en ce qui me concerne une utilisation nomade car vraiment confortable. Félicitations à Meze et à Audiophonics pour le sérieux.
Casque agréable mais un peu basseux
J'ai testé entre autre ce casque sur un IBASSO DX120 acheté peu avant et comparé avec mon AKG K702 ( moins cher )
Bien sûr c'est avec mes oreilles qui sont tout sauf neuves et
" haut de gamme" à la base...
Alors et ce sera le coté négatif du MEZZE NEO 99 c'est qu'il ne fait pas le poids face à l'autre dès qu'il s'agit de musique en haute qualité et subtile... ambiance basseuse, perte de la finesse...
Par contre il est plutôt beau, léger, confortable et très sensible donc utilisable sans ampli casque et économe des batteries...
Donc super pour le tout venant : films, internet, smartphones... il permet d'écouter inversement du compressé même en 128 Kb bien mieux que l'AKG qui est plus exigeant et qui oblige à pousser bien plus le volume
Donc je l'ai gardé, un casque de plus...
Et en ce moment il vaut mieux écouter la musique que les infos si on veut rester en bonne santé...
The Meze 99 Neo audiophile mobile headphones redefine the very term price/performance ratio, offering headphones with contemporary curves and...
