By buying this product you get 194 loyalty points
Meze Liric II headphones feature large isodynamic drivers with Quarter-Wave Resonator Mask (QWRM) to maximize the openness and precision of the soundstage. Thanks to its closed design and optimal wearing comfort, Meze Liric II headphones are ideal for longer listening sessions and nomadic use, in combination with an audiophile walkman or headphone amplifier. Combining elegance and comfort, they feature a superb design with Macassar ebony shells and detachable magnetic ear pads.
Created exclusively for Meze Audio, the MZ4 driver has already proved its worth in the first generation of Meze Liric. With its 30 years of research and development behind it, it is one of the lightest and most advanced Planar Magnetic loudspeakers on the market today, and the 2nd generation of Meze Liric hi-fi headphones continues this tradition with the MZ4 Isodynamic Hybrid Array drivers. Designed in partnership with Rinaro, experts in the development of high-end drivers, these isodynamic models offer an audio experience comparable to that of even more prestigious models such as the Meze Empyrean II and Meze Elite.
The MZ4 driver combines individual spiral and cup-shaped voice coils in the same diaphragm, allowing sound to be targeted more precisely around the natural shape of the ear, for a more selective acoustic performance. The switchback coil is more effective at reproducing low frequencies, and is positioned in the upper part of the driver. The spiral coil is more effective at reproducing mid and high frequencies and is positioned directly above the ear canal, allowing more direct sound waves to enter the ear without delay. This combination enables the headphones to achieve increased exposure of direct sound wave frequencies over the 10 kHz range, as well as improved imaging and localization, by reducing the impact of short-wave delays caused by diffuse field reflections. Response is optimized across the entire reproduced spectrum, resulting in greater treble transparency and deeper, better-defined bass. In addition, two 0.3 Tesla neodymium magnet arrays are placed symmetrically on either side of the diaphragm to guarantee uniform driver control and maximize dynamics. The reinforced polymer housing is designed to withstand the high load of 10.7 N generated by the hybrid magnet array.
Combining Meze Audio's industrial design excellence with Rinaro's high-end technologies, the Meze Liric II is aimed at active audiophiles who enjoy music on the move. These headphones deliver sophisticated sound, characterized by a subtle balance between clarity and warmth. To achieve this feat, the Quarter Wavelength Resonator Mask (QWRM) was developed. This meticulously designed metal component strategically covers certain openings in the driver chassis, effectively attenuating high-frequency peaks above 7 kHz. This innovation guarantees a more pleasant, less fatiguing listening experience for demanding music lovers.
Phase-X technology, integrated into MZ4 drivers, represents a significant advance in the design of closed headphones. Developed by Rinaro to counter the phase distortion usually associated with these models, this patented system ensures an immersive, spatial listening experience. Thanks to the Phase-X system, the precision of spatialization is enhanced, rivalling the performance of open-air headphones, which is particularly remarkable when listening to binaural recordings.
Meze Liric II headphones feature a finely tuned pressure equalization system for optimum in-ear pressure and airflow control. It has also been enhanced to achieve a smoother transition between bass and low midrange. As a result, the MZ4 drivers can utilize both the acoustic volume of the shells and that of the ear cushions. This design considerably reduces the size required for the rear acoustic chamber, enabling Meze Liric II headphones to retain a compact, truly portable profile, without compromising acoustic performance.
Meze Liric II hi-fi headphones are designed to combine comfort, durability and ease of maintenance. The earcups have been redesigned to offer great wearing comfort and effortless maintenance, introducing a removable magnetic design. This evolution is rooted in the tradition of Maramures craftsmanship, preserving the design codes of the first generation while adding warmth with the addition of Macassar ebony wood. The luxurious yet robust character of the Meze Liric II headphones is expressed in every component. It features a solid aluminum frame combined with magnesium shells and temples. The latter are height-adjustable via an anodized aluminum threaded rod, ensuring a perfect fit for all body shapes. The wide earcups surround the ears from afar, without generating the slightest pressure thanks to generous, thick padding. The headband features several symmetrically arranged "+"-shaped cushions, promoting optimum air circulation and limiting heat build-up. Covered in genuine leather, the headband adjusts perfectly for ideal pressure distribution. By following the morphology of the head, it ensures firm, even contact, guaranteeing optimum comfort of use. As a result, Meze Liric II headphones can be worn for long hours without causing the slightest discomfort or excessive overheating.
The Meze Liric II hi-fi headphones come with two cables for easy pairing with any headphone amp or audiophile walkman. The first is a hand-braided copper cable, the result of careful attention to enhancing the listening experience. This top-quality cable features a 4.4 mm termination, compatible with most portable audio players and DACs, offering optimal connectivity. Complementing this is a flexible 3-meter TPE cable with a 3.5 mm jack plug, ideal for use with headphone amplifiers, offering flexibility of use for different listening environments. Furthermore, a 6.35mm jack adapter and an aircraft adapter are supplied for assured compatibility in any situation. Finally, the Meze Liric II headphones also come with a rigid storage pouch, enabling them to be transported and stored safely.
| Specifications | |
| Product type | Headphone |
| Speaker driver type | Rinaro Isodynamic Hybrid Array® MZ4 |
| Headphone type | Closed |
| Ear coupling | Circumaural |
| Frequency response | 4Hz - 92kHz |
| Impedance | 61Ω |
| Nominal SPL | 100dB @ 1mW |
| Max SPL | 130 dB |
| Total harmonic distortion (THD) | < 0.15% |
| Weight | 427g |
| MZ4 DRIVER SPECIFICATIONS | |
| Driver shape | Ovoid |
| Size | 92 x 63mm |
| Weight | 71g |
| Casing | Polymère renforcé de fibre de verre |
| Diaphragm type | Rinaro Isoplanar® MZ4 |
| Active area | 3507mm² |
| Diaphragm weight | 0.08g |
| Acoustic mass | 6.5kg/m⁴ |
| General | |
| Couleur | Ebony |
| Package | 1x Meze Liric II 1x 1.3 m braided Furukawa PCUHD copper cable with 4.4 mm jack plug 1x 3 m flexible TPE cable with 3.5 mm jack plug 1x 6.35 mm jack adapter 1x aircraft adapter 1x rigid carrying case |
| Color | Wood |
| Impedance (Ω) | 61 |
| Efficiency / Sensitivity (dB) | 100.0 |
| Lowest frequency (Hz) | 4 |
| Highest frequency (Hz) | 92000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Cable termination | Jack 6.35mm |
| Cable termination | Jack 4.4mm |
| Headphone / Earphone connector | Jack 3.5mm |
