MEZE POET Headphones
New
The Meze Poet magnetic planar headphones are a blend of elegance and technology, providing a detailed and harmonious reproduction of your music.
By buying this product you get 199 loyalty points
Reference : 20529
1 999,00 €tax incl.
1 665,83 € tax excl.
Meze Poet Planar Magnetic Open-Back Headphones 55 Ohm 101dB 4Hz-96kHz
MEZE POET picture
The Meze Poet magnetic planar headphones are a blend of elegance and technology, providing a detailed and harmonious reproduction of your music. Meze Audio has taken care to select top-of-the-range materials such as its 92x63mm Rinaro Isodynamics MZ6 hybrid driver, a magnesium chassis and a soft leather headband lined with a titanium alloy headband. An audiophile cable with copper conductors and 6.35mm jack termination ensures a high level of compatibility. As you can see, the Meze Poet is designed for demanding music lovers.
Meze Poet: Rinaro Isodynamics MZ6 hybrid driver
The planar magnetic driver for Meze Poet headphones has been designed in partnership with RINARO to deliver an exceptional listening experience. The driver features a reinforced polymer housing, an ultra-light semicrystalline polymer film diaphragm and a hybrid magnet array. It offers a very low level of distortion throughout its 4Hz - 96kHz frequency spectrum. In addition, it features 2 different coils, one for bass and one for treble, working in harmony for immersive bass and exceptional detail.
MEZE POET driver
Meze Poet: a balanced sound signature
The Meze Poet is a top-quality pair of headphones capable of delivering a balanced sound signature for the ultimate listening experience. Indeed, its sound signature is characterized by deep bass, clear mids and detailed highs. Each frequency spectrum is clearly audible and in harmony with the others. As an added bonus, Dan Clark Audio's Acoustic Metamaterial Tuning System (AMTS) eliminates unwanted high-frequency peaks for even greater clarity and listening pleasure.
The signature sound of MEZE POET
Meze Poet: highly compatible headphones
The Meze Poet's 55-ohm impedance and 101dB sensitivity make it a highly controllable set of headphones. In addition, they feature a 3.5mm jack connector and a detachable cable with 6.35mm jack termination.
MEZE POET's cable
Meze Poet: a high-end experience
Meze has made no concessions with its Poet headphones: as elegant as they are comfortable, they are designed with durable, lightweight materials. The ear pads feature a magnetic system for easy replacement. The set is completed by a practical carrying case to protect your headphones.Exploded view of the MEZE POET
Product typeHeadphone
Headphone typeCircumaural closed-back
ShapeOvoid
DriverPlanar magnetic (Rinaro Isodynamic® Hybrid Array MZ6)
Driver weight73g
Diaphragm size92 x 63mm
Frequency response4Hz-96kHz
Impedance55 ohm
Sensitivity101 dB SPL/mW at 1 kHz
Maximum SPL> 130dB
THD< 0.05%
Headphone connectors2x jack 3.5mm
Detachable cable
Cable length2.5m
Cable terminaisonJack 6.35mm
Weight350g (without pads)
Package1x Meze Poet headphones
1x Cable 2x jack 3.5mm to termination jack 6.35mm
1x Protective cover
ColorSilver
Impedance (Ω)55
Efficiency / Sensitivity (dB)101.0
Lowest frequency (Hz)4
Highest frequency (Hz)96000
WirelessNo
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
MEZE POET Planar Magnetic Open-Back Headphones 55 Ohm 101dB 4Hz-96kHz
