MONOLITH M1060 Over Ear Open Back Planar Magnetic Headphone 96dB 50 Ohm 10Hz - 50kHz
The Monolith M1060 headphones are the ideal listening solution to get the most out of your music. Featuring large 106mm Planar Magnetic drivers, the M1060 delivers a precise and rich sound reproduction, allowing you to capture every detail of your music. With a spectacular sound image, low distortion and perfectly balanced sound, the Monolith M1060 is a true audiophile headphone!
By buying this product you get 34 loyalty points
Reference : 14383
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 16-04-2025.
Monolyth M1060 Casque Ouvert Supra-Aural Planar Magnetic
Planar Magnetic Drivers
The M1060 is equipped with Planar Magnetic speakers. These have a flat diaphragm directly equipped with magnets. This technology, reserved for high-end headphones, allows a lower level of distortion, a better bass reproduction and a much more accurate sound image. The diaphragms of the M1060 have a large diameter of 106mm.
Over-Ear Open Back Design
The headphones adopt an open design, offering a more open and spacious sound stage than closed headphones that sometimes sound muffled. This makes the M1060's music experience more immersive, putting you at the heart of your music.
Confort
The Monolith M1060 has been designed to provide excellent comfort for long listening sessions. The wide, thick ear cushions and padded headband allow the headphones to be quickly forgotten for a pleasant listening experience.
Product typeHeadphone
Headphone typeOpen Back
Over-Ear
Drivers typePlanar Magnetic
Drivers diameterØ106mm
Magnets structureLinear symmetry
Magnets materialNeodymium
Max power handling10W (for 200ms)
Max SPL> 130dB
Frequency response10Hz - 50kHz
THD< 1% @ 1mW, 1kHz
Impedance50Ω
Efficiency96dB/1mW
Optimal power200mW - 4W
Cable length1.90m
Weight500g
Package1x Monolith M1060
1x Braided Jack 3.5mm cable
1x Jack 3.5mm to Jack 6.35mm adapter
1x Transport bag
ColorWalnut
Impedance (Ω)50
Efficiency / Sensitivity (dB)96.0
Lowest frequency (Hz)10
Highest frequency (Hz)50000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
3 reviews
Excellent
Très bon produit conforme à toutes mes attentes. Merci Audiophonics.
This review has been posted for MONOLITH M1060 Over Ear Open Back Planar Magnetic Headphone 96dB 50 Ohm 10Hz - 50kHz
Bargains!
Absolutely best Headphones you can get for cheap price. Very pleasant and big sounding. Not very heavy and soft pads for ear. Soundstage is wide and transparency with my Canor TP10 amplifier. Strong recommended. If you want smooth and natural sounding headphones, buy these! Best regards Vesa Niskanen Finland
Clarté et Transparence
Oui ce casque est de part sa technologie assez exceptionnel, surtout au regard de son prix, par rapport à la concurrence. Il respecte les détails, les notes, n'en rajoute jamais, donne juste l'essentiel, la musique. Même sur des bruits de forêt ou cours d'eau, pris sur le Net, on a l'impression d'y être ; Surprenez vous à tourner la tête, à certains bruits tellement présents. Alors oui, très satisfait de mon achat.
 (4)
The Monolith M1060 headphones are the ideal listening solution to get the most out of your music. Featuring large 106mm Planar Magnetic drivers,...
