MOONDROP EDGE Wireless Headphones White
The Moondrop Edge are dynamic headphones with a 40mm driver and wireless connectivity via LDAC-compatible Bluetooth 5.4. This makes them ideal for enjoying high-resolution sources up to PCM 24bit 96kHz.
Reference : 20400
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 02-05-2025.
Moondrop Edge Dynamic Wireless Headphones Bluetooth 5.4 LDAC Ø40mm 20Hz-20kHz White
Moondrop EDGE picture
The Moondrop Edge are dynamic headphones with a 40mm driver and wireless connectivity via LDAC-compatible Bluetooth 5.4. This makes them ideal for enjoying high-resolution sources up to PCM 24bit 96kHz. In addition, it features hybrid ANC (Active Noise Cancellation) for considerable noise reduction during your listening sessions, and beamforming noise reduction for clear phone calls.  With an impressive 48-hour battery life, extendable to 4 hours after just 5 minutes' charging, these headphones are the ideal companion for everyday use.
Moondrop EDGE highlights
Moondrop Edge: 40mm dynamic loudspeaker
The Edge is equipped with a 40mm dynamic driver. This incorporates a composite cone with flexible suspension and titanium-plated dome, ensuring excellent definition and natural texture in the low-mids. The diaphragm is combined with a CCAW voice coil and N52 magnetic circuit, guaranteeing low distortion and a wide dynamic range. The driver also benefits from a custom acoustic cavity, isolated from electronic circuits to avoid interference.
The Moondrop EDGE speaker
Moondrop Edge: 3 operating modes
The Edge's active noise cancellation (ANC) is based on a hybrid FF + FB (Feedforward + Feedback) technology, using both the surrounding noise and an analysis of the signal produced to elaborate a phase signal opposite to the noise detected. In addition, a transparency mode is also available, so you can listen to your favorite tunes while being aware of your surroundings.
Furthermore, for effective noise reduction during phone calls, the Edge is equipped with four microphones for beamforming noise reduction. This technique relies on several microphones picking up the same sound source. However, due to their different placements, the interference picked up by each of these microphones will be different, enabling them to be discriminated and suppressed.
Moondrop EDGE operating modes
Moondrop Edge: Excellent Bluetooth connectivity
To ensure stable signal transmission in any situation, the Edge incorporates a large Bluetooth antenna, enabling it to maintain a perfect connection even in complex electromagnetic environments. Moreover, the Edge is compatible with the Bluetooth LDAC codec, enabling high-resolution, broadband transmission of your favorite tunes.
Bluetooth connectivity on the Moondrop EDGE
The Moondrop EDGE battery
Moondrop Edge: Autonomy and fast charging
Designed to take you anywhere, the Edge features a 48-hour battery life and a quick-charge function that recovers 4 hours of listening time in just 5 minutes.
Moondrop Edge: Ergonomics and wearing comfort
Particular attention has been paid to comfort and ergonomics, with memory foam pads adapted to the shape of the skull. For added practicality, the helmet features folding aluminum hoops that are both attractive and durable.
Moondrop EDGE, ergonomic headphones
Moondrop Edge: VDSF model
The Edge headphones have been designed to offer a frequency response as close as possible to the VDSF model. And thanks to the MOONDROP Link app available for Android and iOS, you can choose from several frequency response models, with more or less room for low frequencies.
The Moondrop EDGE frequency response curve
Product typeWireless headphones
Bluetooth version5.4
Bluetooth transmission protocolsADP / AVRCP / HFP / HSP
Supported Bluetooth codecsSBC / AAC / LDAC
Charging portUSB-C
Operating distance10m unobstructed
Driver40mm dynamic driver
Charging time1.5h
Autonomy48h
ColorWhite
Package1x Moondrop Edge
1x USB-A to USB-C cable
1x Carrying case
Color
  • White
Impedance (Ω)
  • NC
Efficiency / Sensitivity (dB)
  • N/A
Lowest frequency (Hz)
  • 20
Highest frequency (Hz)
  • 20000
Wireless
  • Yes
Cable termination
  • Wireless
Headphone / Earphone connector
  • USB
  • Wireless (Bluetooth)
MOONDROP EDGE Dynamic Wireless Headphones Bluetooth 5.4 LDAC Ø40mm 20Hz-20kHz White
The Moondrop Edge are dynamic headphones with a 40mm driver and wireless connectivity via LDAC-compatible Bluetooth 5.4. This makes them ideal for...
