MOONDROP PARA Headphones
The Moondrop Para is a high-quality headphone based on Planar Magnetic technology. It has inherited part of the structure of its predecessor, the Moondrop Venus.
4.3 / 5
By buying this product you get 31 loyalty points
Reference : 18561
319,00 €tax incl.
265,83 € tax excl.
Shipping date: 17-10-2025.
MOONDROP PARA Planar Magnetic Circumaural Open-back Audio Headphone Ø100mm 101dB 8Ω 15Hz-53kHz
MOONDROP PARA headphones picture
The Moondrop Para is a high-quality headphone based on planar magnetic technology. It has inherited part of the structure of its predecessor, the Moondrop Venus. The advantage of planar magnetic headphones lies in the fact that the stresses applied to the diaphragm are perfectly uniform, while generating less unwanted residual vibration than in the case of dynamic headphones. The Moondrop Para features a diaphragm no less than Ø100mm in diameter, coupled with FDT ("Full Drive Technology").
MOONDROP PARA highlights
Moondrop Para: a 100mm driver
Unlike traditional magnetic planar drivers, the Moondrop Para adopts an ultra-wide Ø100mm diaphragm and Full Drive Technology (FDT). In other words, the entire surface of the diaphragm is affected by the magnetic field, giving the Moondrop Para a level of performance close to that of electrostatic driver headphones.
The MOONDROP PARA speaker
Moondrop Para: FDT (Full Drive Technology)
Operation of a traditional diaphragm
How a traditional magnetic planar diaphragm works
Only the central part of the diaphragm is driven, which can lead to unwanted vibrations, making treble detail less precise and causing timbre distortion.
Diaphragm operation with FDT
Planar magnetic diaphragm + FDT technology
With FDT technology, the entire circuit is controlled. The result is a uniform movement of the vibrating surface approaching that of electrostatic headphones, with highly detailed highs that are far more rich and well-sounding.
Moondrop Para: optimized N52 magnet array
The Para planar magnetic headphones adopt no fewer than 36 N52 neodymium magnets to cover the entire diaphragm surface. Thanks to the FEA optimization system, the magnetic field parallel to the diaphragm is evenly distributed, further reducing residual, non-linear diaphragm vibrations.
Conventional magnetic field
Magnetic field optimized by FEA analysis
Moondrop Para: High-fidelity headphone that is easy to control
Moondrop has chosen to offer headphones that are easy to drive. The Para's impedance is 8 Ohm, yet the brand has made no concessions to the quality of the structure, components or sound reproduction of its headphones. As a result, these headphones have the advantage of being compatible with a large number of Hi-Fi devices, from high-end amplifiers to portable equipment.
The headphones' diaphragm is made from a new flexible composite material with high damping properties, thus reducing unwanted vibration residues and improving the behaviour of the headphones. The two-dimensional structure of Para headphones also incorporates TBT (Tension Balancing Technology) to balance stress on the diaphragm surface.
Photo of Moondrop Para headphones
Moondrop Para headphone structure
Diagram of the Moondrop Para structure
1Internal structure with integrated chassis
2N52 neodymium magnet arrays
3Diaphragm holder
4Diaphragm
Moondrop Para: natural timbre and low distortion
With the settings applied to the Para by Moondrop, the headphones are able to deliver a very good acoustic performance accompanied by a textured sound rendering. The amplitude of its frequency response gives it an open, natural soundstage, with extended, rich and precise treble.
Moondrop Para's frequency responsea
The Para moondrop offers a low level of non-linear distortion (less than 0.5%) even at pressures exceeding 1Pa. This is why it has a wide dynamic range when driven with sufficient energy.
Moondrop Para distortion level
Universal jack cable
The Moondrop Para comes with a 3.5mm jack cable to two 3.5mm jack headphone connectors. It will therefore be compatible with a large number of devices on the market.
Moondrop Para headphones connectors
Product typeOpen circumaural headphones
Speaker typePlanar magnetic
DIapohrgm diameterØ100mm
Magnetic systemArray of 36 Neodymium N52 magnets
Sensitivity101dB/Vrms (@1kHz)
Impedance8 Ohm +/-6 15% (@1kHz)
Frequency response15Hz - 53kHz
Effective frequency response20Hz - 20kHz
Headphone connectorsJack 3.5mm
ColorSilver
Package1x Moondrop Para headphone
1x Cable 2x jack 3.5mm to terminaison jack 3.5mm
1x Adapter jack 3.5mm to jack 6.35mm
ColorSilver
Impedance (Ω)8
Efficiency / Sensitivity (dB)101.0
Lowest frequency (Hz)15
Highest frequency (Hz)53000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
3 reviews
Supraṇava
Ordering worked perfectly and delivery was superb fast to Finland. Ten points and a parrot badge:-)
This review has been posted for MOONDROP PARA Planar Magnetic Circumaural Open-back Audio Headphone Ø100mm 101dB 8Ω 15Hz-53kHz
Impédance...
Bonsoir.
À mon humble avis, les amplificateurs de casque ne sont pas adaptés à une impédance de 8 ohms. Ce casque est comme une petite enceinte acoustique.
Donc, il faut le brancher sur la sortie de puissance d'un amplificateur.
Pas nécessairement puissant : la question n'est pas d'avoir du voltage, car il a une bonne sensibilité, mais du courant, afin que l'ampli ne s'effondre pas.
Je vous salue cordialement.
PS. Les 5 étoiles sont pour audiophonics, je n'ai pas écouté le casque...
Moondrop para
J’ai fait l’achat de ce casque il y à bientôt deux mois, sans avoir fait d’essai préalable. Casque en 08 ohms sensé pouvoir être drivé par in peu n’importe quoi comme j’avais pu le lire ca et là.
Quelle déception…..que ce soit en direct sur mes divers appareils équipés de prise casque ou sur mon ampli casque à tubes littledot mk2 , et bien le volume sonore reste faible, bien trop faible pour mes oreilles. La qualité sonore du casque en lui même n’est pas en cause. La spacialisation est excellente, l’equilibre entre les fréquences est bonne mais je ne peux tout simplement pas en profiter…..il faudrait simplement pouvoir monter le son ce qui poir le moment m’est impossible. Le littledot mk2 s’effondre dès que je monte un peu le son et quelque soit les réglages sur l’ampli.
Voilà, j’attend desormais de trouver un ampli casque adapté,capable de booster suffisamment mon casque. Pour le moment je ne trouve pas d’ampli qui accepte dans ses specifications la valeur de 8ohms. Un conseil serait le bienvenu, si audiophonics lit mon commentaire, ou toute autre personne possedant un casque similaire.
The Moondrop Para is a high-quality headphone based on Planar Magnetic technology. It has inherited part of the structure of its predecessor, the...
