SENDY AUDIO APOLLO Planar Magnetic Headphone 95dB 16 Ohm 20Hz-40kHz
Sendy Audio unveils the Apollo, an exceptional headset using Planar Magnetic technology for an incredibly accurate and precise sound. The luxurious wood and metal design conceals a true concentrate of technology, designed to offer the most faithful and richest sound reproduction possible, for the most immersive listening experience.
By buying this product you get 40 loyalty points
Reference : 16148
409,00 €tax incl.
340,83 € tax excl.
Shipping date: 23-04-2025.
Sendy Audio Apollo
Casque Planar Magnetic 95dB 16 Ohm 20Hz-40kHz
Sendy Audio Apollo Casque Planar Magnetic 95dB 16 Ohm 20Hz-40kHz
Quad-Former Technology
The Planar Magnetic drivers in the Apollo headphones use Quad-Former technology. This means that each diaphragm has dual magnets and dual coils on each side for a total of 4 coils per diaphragm. The coils are evenly distributed over the entire surface of the diaphragm. This design allows to obtain an optimal diffusion, the whole membrane reacting in the same way for a given frequency. The double magnets allow to obtain an identical magnetic power on the whole field. The Sendy Audio Apollo thus presents an efficient conversion of electroacoustic energy, associated with extremely low distortion, very good coherence and optimal sound fidelity.
The diaphragm itself uses a composite material with high damping capacity, allowing for natural, smooth vocals and solid bass. The ultra-thin and very rigid material in charge of high frequency reproduction allows to reach 40kHz for brilliant and detailed highs.
Design & Ergonomics
The Sendy Audio Apollo also offers a beautiful design, with the headphones mixing both a steel mesh and a wooden surround. The holes in the shell, in addition to giving the headphones a special aesthetic, allow for acoustic optimization. The whole thing is precision-machined using a CNC (numerical control), then sandblasted, polished and painted.
The headband uses a goat leather covering and its design allows a comfortable wearing of the helmet. The cushions them integrate a foam with memory of form adapting perfectly to the contours of the ear. In addition, they are easily removable and therefore replaceable.
Cable & Accessories
The Sendy Audio Apollo comes with a high quality detachable cable. The cable has braided OCC copper conductors for excellent signal transmission.
The headset also comes with a carrying case and a fabric pocket for storing the cable.
Product typeHeadphone
Headphone typePlanar Magnetic
Headphone formatOver-ear
Transducers diameterØ68mm
Frequency response20Hz - 40kHz
Sensitivity95dB ±3dB
Impedance16Ω ±15%
Cable length2m ±0.2m
ConnectorBalanced Jack 4.4mm
Weight395g
Package1x Sendy Audio Apollo
1x Balanced Jack 4.4mm cable
1x Carrying case
1x Cable storage bag
1x 4.4mm jack to 3.5mm jack adapter
Impedance (Ω)16
Efficiency / Sensitivity (dB)95.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 2.5mm
Sendy Audio unveils the Apollo, an exceptional headset using Planar Magnetic technology for an incredibly accurate and precise sound. The luxurious...
