SENDY AUDIO PEACOCK HiFi Headphone Planar Magnetic Circumaural 50 Ohm 103dB 20Hz-40kHz
Exceptional sound quality, comfort, high-end materials and sublime design, these are all elements that make the Sendy Audio Peacock an excellent planar magnetic headphone to enjoy your music. With its large 88mm diameter planar magnetic transducers and high efficiency electro-acoustic energy conversion, the Peacock manages to reveal a sound reproduction that is both precise and pure, with detailed highs and natural mids and vocals, while providing deep bass.
By buying this product you get 159 loyalty points
Reference : 15723
1 599,00 €tax incl.
1 332,50 € tax excl.
Sendy Audio Peacock
Sendy Audio Peacock Casque HiFi Planar Magnetic Circumaural 50Ω 103dB 20Hz-40kHz
The diaphragm is made of an ultra thin and very rigid composite material, ensuring clear and transparent high frequencies, without being aggressive. The soundstage is particularly wide and coherent.
Quad-Former Technology
The Sendy Audio Peacock benefits from the Quad-Former technology. The headphone integrates planar magnetic drivers, each composed of a double magnet and two double-sided coils on the membrane. Thus, each face of the membrane is dressed with two coils, for a total of four coils. This particular design ensures excellent magnetic energy conversion and low distortion for a lively and dynamic sound reproduction.
Ultra thin composite diaphragm
After more than two years of experimentation, Sendy Audio has succeeded in designing the perfect composite membrane, with optimized thickness and rigidity. The base material provides excellent damping for natural reproduction and deep, punchy bass. The part in charge of the high frequencies restitution is extremely thin and rigid for precise but not aggressive highs.
The speaker enclosure is made of CNC machined aluminum. After extensive testing, the size and position of each hole could be precisely defined. Each row of holes allows a uniform distribution of sound over the entire frequency range.
Comfortable headband
The support band is covered with goat leather, a resistant material. It is dressed with golden seams of the most beautiful effect. The design of this headband has been thought to allow optimal comfort, even during long listening sessions.
Memory foam earpads
The earpads use the same goatskin covering as the headband, with a memory foam filling that again ensures great comfort. Their ergonomic shape adapts perfectly to the shape of the ear and ensures a perfect seal to avoid any sound leakage.
An elegant and luxurious design
The Sendy Audio Peacock's grilles give this headphone a unique and sumptuous design. In addition, the double black and gold grille also plays a role in the undeniable sound quality of these headphones. All the gold parts on the headphone shell are also plated with 24k gold. The wooden body is CNC-cut.
Cable & Adapters
The Sendy Audio Peacock is delivered with a high quality cable (detachable), with 8 OCC 6N copper conductors braided between them, ensuring excellent conductivity and transmission of the audio signal. The connectors used on the headphone side are Mini XLR 4 pins, where the input connector is a balanced 4.4mm jack. In addition, adapters Jack 6.35mm and XLR 4 pins are provided with the headphone.
Product typeHeadphone
Headphone typePlanar magnetic
Headphone formatOver ear
Transducers dimensionsØ88mm
Frequency response20Hz -40kHz
Sensitivity103dB ±3dB
Impédance50Ω ±15%
Cable length2m ±0.2m
Cable input connectorBalanced Jack 4.4mm
Cable conductors6N OCC Copper
Body materialsWood and metal
Weight578g
Package1x Sendy Audio Peacock gold
1x Jack cable 2m
1x Jack 4.4mm to Jack 6.35mm adapter
1x Jack 4.4mm to XLR 4 pins adapter
1x Carrying case
1x Cable bag
ColorWalnut
Impedance (Ω)50
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationXLR 4-pin
Cable terminationJack 6.35mm
Cable terminationJack 4.4mm
Headphone / Earphone connectorMini XLR 4 Pins
Excellent…
I was looking for planar magnetic headphones and chose Sendy peacocks. Now I am listening last 4 days intensively via Hafler HA75 tube headphone amp and can’t tell you how how I am satisfied. Sound as well as build quality is excellent. Well done Sendy!
Thank you Audiophonics for super accurate delivery!
This review has been posted for SENDY AUDIO PEACOCK HiFi Headphone Planar Magnetic Circumaural 50 Ohm 103dB 20Hz-40kHz
Exceptional sound quality, comfort, high-end materials and sublime design, these are all elements that make the Sendy Audio Peacock an excellent...
