SHANLING HW600 Headphones
The Shanling HW600 headphone is a high-end supra-aural headphones based on a magnetic planar driver measuring no less than 110x86mm. Its design is based on superior materials and its appearance is most elegant. It has, for example, a sturdy aluminum frame, leather ear pads and a double neodymium magnet array, with 14 magnets providing a flux density of 1.8T.
By buying this product you get 109 loyalty points
Reference : 19906
1 099,00 €tax incl.
915,83 € tax excl.
Shipping date: 16-04-2025.
Shanling HW600 Headphones Supra-Aural Open-Back Planar Magnetic 30 Ohm 104dB 12Hz-40KHz
Photo du casque audio SHANLING HW600
The Shanling HW600 headphone is a high-end supra-aural headphones based on a magnetic planar driver measuring no less than 110x86mm. Its design is based on superior materials and its appearance is most elegant. It has, for example, a sturdy aluminum frame, leather ear pads and a double neodymium magnet array, with 14 magnets providing a flux density of 1.8T. Its dual acoustic chamber allows the driver performance to be fully optimized. Looking at the measurements of the HW-600 headphone, we note its 30 ohm impedance and 104dB sensitivity, making it easy to drive and suitable for a wide range of devices. In addition, it features an extended frequency response, in both bass and treble (12Hz-40kHz), for the most detailed reproduction. A true jewel of design and technology, these headphones will satisfy the most demanding audiophiles.
Shanling HW600: 110mm magnetic planar diaphragm
The magnetic planar diaphragm of the Shanling HW600 is a large 110x86mm diaphragm. It is made of an ultra-fine 0.8um polymer material. These characteristics offer a high level of dynamic range over a wide frequency response curve.
Photo du diaphragme planar magnétique du HW600
Bobines aluminium du Shanling HW600
Shanling HW600: silver-plated aluminum coils
The coils used in the HW600 are made of silver-plated aluminum, providing a high level of conductivity. The result is enhanced sensitivity for superior audio resolution.
Shanling HW600: high-performance magnets
The magnet arrays in each earpiece of the HW600 are made up of no fewer than 14 neodymium magnets for a flux density of 1.8T. They are distributed in such a way as to ensure uniform, linear operation.
Les aimants du casque Shanling HW600
La double chambre acoustique du shanling HW600
Shanling HW600: dual acoustic chambers
The HW600 diaphragm is surrounded by two acoustic chambers. This configuration greatly enhances driver performance, while reducing distortion to match the HE600's target frequency response curve as closely as possible.
Shanling HW600: an audiophile cable
A detachable 2x jack 3.5mm to jack 4.4mm balanced cable. This cable features 4 single-crystal copper conductors for optimum signal transmission.
Photo du HW600 avec son câble détachable
Shanling HW600 test by Headfonics
The Shanling HW600 marks a strong start for the company in the headphones market with a remarkably easy-to-drive setup and tuning that is ideal for vocal enthusiasts. The sound profile is well distinguished from competitors, focusing on the timbre. The high sensitivity and compact design ensure great synergy with powerful portable gears, freeing listeners from the desktop setup.
Product typeHeadphone
Headphone typeSupra-aural
DiaphragmPlanar magnetic
Diaphragm diameter110 x 86mm
Impedance30 ohm
Sensitivity104 ±3dB
Frequency response12Hz-40kHz
Headphone connectorJack 3.5mm
CableDetachable cable 2x jack 3.5mm to balanced jack 4.4mm termination
Cable length1.5m
HeadbandAdjustable
Weight480g
Package1x Shanling HW600 over-ear headphones
1x Detachable cable 2x 3.5mm jack to 4.4mm jack termination
Impedance (Ω)30
Efficiency / Sensitivity (dB)104.0
Lowest frequency (Hz)12
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
SHANLING HW600 Headphones Supra-Aural Open-Back Planar Magnetic 30 Ohm 104dB 12Hz-40KHz
The Shanling HW600 headphone is a high-end supra-aural headphones based on a magnetic planar driver measuring no less than 110x86mm. Its design is...
