SIVGA LUAN Open-Back Dynamic Over-Ear Headphone Ø50mm 38 Ohm 100dB 20Hz-40kHz Wood Black
Sivga's Luan is an open-back, over-earHi-Fi headphone featuring dynamic transducers. With an elegant, comfortable design, they guarantee high-quality, precise, rich and detailed sound reproduction over its 20Hz-40kHz frequency range, thanks to their Ø50mm diameter transducers.
By buying this product you get 35 loyalty points
Reference : 18235
359,00 €tax incl.
299,17 € tax excl.
SIVGA LUAN
Open-Back Dynamic Over-Ear Headphone Ø50mm 38Ω 100dB 20Hz-40kHz Wood/Black
SIVGA LUAN Casque Dynamique Ouvert Circumaural 38Ω 100dB 20Hz-40kHz
Sivga's Luan is an open-back, over-ear Hi-Fi headphone featuring dynamic transducers. With an elegant, comfortable design, they guarantee high-quality, precise, rich and detailed sound reproduction over its 20Hz-40kHz frequency range, thanks to their Ø50mm diameter transducers. Its solid wood finish, memory foam earpads and quality components such as nickel-plated polymer transducers, NdFeB neodymium magnets and copper-plated aluminum coils ensure exceptional comfort and immersive, powerful sound reproduction thanks to its high dynamic range. Moreover, as well as being compatible with headphone amplifiers and Hi-Fi players, its low impedance of 38 ohms means it can also be adapted to more conventional source devices such as smartphones and computers.
Dynamic transducers for balanced sound reproduction
The Sivga Luan's Ø50mm nickel-plated polymer transducers give it a strong dynamic response. In fact, the transducers were chosen for their lightness, high rigidity and elasticity. It is this combination of characteristics that gives these headphones their tonal wellbalance. The NdFeB neodymium magnets add power to the drivers, while the highly sensitive copper-plated aluminum coil gives a smooth, transparent sound. Overall, these headphones offer a wide soundstage and a natural, fluid, detailed and immersive audio experience.
Optimum comfort
Sivga Luan audio headphone incorporate noble materials. Its shell is made of ash wood, a material known for its acoustic properties that prevent distortion and maintain a natural sound. Then there's the self-adjusting elastic headband system, which adapts to the morphology of many users. Next come leather-covered memory foam earpads. The design of the earcups prevents pressure on the user's ears, while providing effective sound isolation. With the LUAN, SIVGA offers a headphone perfectly suited to long listening sessions.
Audiophile accessories
With its Luan headphone, Sivga also supplies a double 3.5mm jack cable with 3.5mm jack termination. This 1.6m-long cable is made of TPU thermoplastic polymer, making it tangle-resistant and eliminating frictional noise. A 3.5mm jack to 6.35mm jack adapter is also included for compatibility with some headphone amplifiers.
SIVGA LUAN Open-Back Dynamic Over-Ear Headphone Ø50mm 38Ω 100dB 20Hz-40kHz Wood/Black
Product typeHeadphone
Type de casque Over-ear
Headphone structureOpen-back
Driver typeDynamic
Driver diameterØ50mm
ComponentsNickel-plated polymer diaphragm
Organic carbon fiber dome
Copper-plated aluminum coil
Oversized NdFeB neodymium magnet (24.5 mm diameter - 350 kj/m)
Frequency response20Hz-40kHz
Sensitivity100dB +/-3dB
Impedance38 ohms +/-15%
Headphone connectors2x 3.5mm mono jack
Cable length160cm
Cable terminaison3.5mm jack
Weight364g
ColorWood and black
Package1* SIVGA LUAN headphone
1* Hard carrying case
1* Soft storage pouch
1* 3.5mm stereo to 2x3.5mm mono cable (160 cm)
1* 3.5mm jack to 6.35mm jack adapter
ColorWood
Impedance (Ω)38
Efficiency / Sensitivity (dB)100.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
Sivga's Luan is an open-back, over-earHi-Fi headphone featuring dynamic transducers. With an elegant, comfortable design,...
