By buying this product you get 34 loyalty points
Sivga's Luan is an open-back, over-ear Hi-Fi headphone featuring dynamic transducers. With an elegant, comfortable design, they guarantee high-quality, precise, rich and detailed sound reproduction over its 20Hz-40kHz frequency range, thanks to their Ø50mm diameter transducers. Its solid wood finish, memory foam earpads and quality components such as nickel-plated polymer transducers, NdFeB neodymium magnets and copper-plated aluminum coils ensure exceptional comfort and immersive, powerful sound reproduction thanks to its high dynamic range. Moreover, as well as being compatible with headphone amplifiers and Hi-Fi players, its low impedance of 38 ohms means it can also be adapted to more conventional source devices such as smartphones and computers.
The Sivga Luan's Ø50mm nickel-plated polymer transducers give it a strong dynamic response. In fact, the transducers were chosen for their lightness, high rigidity and elasticity. It is this combination of characteristics that gives these headphones their tonal wellbalance. The NdFeB neodymium magnets add power to the drivers, while the highly sensitive copper-plated aluminum coil gives a smooth, transparent sound. Overall, these headphones offer a wide soundstage and a natural, fluid, detailed and immersive audio experience.
Sivga Luan audio headphone incorporate noble materials. Its shell is made of ash wood, a material known for its acoustic properties that prevent distortion and maintain a natural sound. Then there's the self-adjusting elastic headband system, which adapts to the morphology of many users. Next come leather-covered memory foam earpads. The design of the earcups prevents pressure on the user's ears, while providing effective sound isolation. With the LUAN, SIVGA offers a headphone perfectly suited to long listening sessions.
With its Luan headphone, Sivga also supplies a double 3.5mm jack cable with 3.5mm jack termination. This 1.6m-long cable is made of TPU thermoplastic polymer, making it tangle-resistant and eliminating frictional noise. A 3.5mm jack to 6.35mm jack adapter is also included for compatibility with some headphone amplifiers.
| Specifications | |
| Product type | Headphone |
| Type de casque | Over-ear |
| Headphone structure | Open-back |
| Driver type | Dynamic |
| Driver diameter | Ø50mm |
| Components | Nickel-plated polymer diaphragm Organic carbon fiber dome Copper-plated aluminum coil Oversized NdFeB neodymium magnet (24.5 mm diameter - 350 kj/m) |
| Frequency response | 20Hz-40kHz |
| Sensitivity | 100dB +/-3dB |
| Impedance | 38 ohms +/-15% |
| Headphone connectors | 2x 3.5mm mono jack |
| Cable length | 160cm |
| Cable terminaison | 3.5mm jack |
| General | |
| Weight | 364g |
| Color | Wood and Brown |
| Package | 1x SIVGA LUAN headphone 1x Hard carrying case 1x Soft storage pouch 1x 3.5mm stereo to 2x3.5mm mono cable (160 cm) 1x 3.5mm jack to 6.35mm jack adapter |
| Color | Wood |
| Color | Brown |
| Impedance (Ω) | 38 |
| Efficiency / Sensitivity (dB) | 100.0 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 40000 |
| Wireless | No |
| Cable termination | Jack 6.35mm |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | Jack 3.5mm |
