Dynamic Closed-Back Over-Ear Headphone Circumaural 32Ω 108dB 20Hz-20kHz Zebrano
Sivga's Oriole closed-back dynamic headphones are a perfect combination of performance, design and comfort. Each headset has a 50mm dynamic driver developed by the brand, revealing an expressive and musical reproduction. A sound reproduction characterized by present but not intrusive bass, soft and articulated mids and a detailed treble without aggressiveness. The headphone also shows a wide sound stage, offering a nice separation of the instruments.
The ergonomic headband of the Oriole offers a great wearing comfort, even during long listening sessions. This comfort is complemented by the use of memory foam and leatherette for the headphone cushions. The earpieces are also mounted on 180° swivel hinges, allowing them to adapt perfectly to the shape of the user's head while facilitating storage.
The earpieces are precision-machined with a 5-axis CNC (computer numerical control) from a piece of high-quality Zebrano wood. This is a particularly robust wood used in the manufacture of certain musical instruments. The sanding and varnishing is meticulously done by hand by the brand's craftsmen. The wood is then air-dried. Each earpiece is finally laser engraved with the brand's logo, before receiving a final protective varnish for piano.
The detachable cable of the Sivga Oriole allows, if the need arises, an upgrade. The connectors on the headphone side are 2.5mm mono jack. On the source side, there is a 3.5mm stereo jack.
| Specifications | |
| Product type | Headphone |
| Headphone type | Circumaural |
| Headphone structure | Closed-back |
| Driver type | Dynamic |
| Driver diameter | Ø50mm |
| Frequency response | 20Hz-20kHz |
| Sensitivity | 108dB ±3dB |
| Impedance | 32Ω ±15% |
| Cable length | 1.8m |
| Cable connectors | 2x Mono Jack 2.5mm 1x Stereo Jack 3.5mm  |
| General | |
| Finish | Zebrano |
| Weight | 280g |
| Package | 1x Sivga Oriole 1x Fabric carrying pouch 1x Jack 2.5mm to Jack 3.5mm cable 1x Jack 3.5mm to Jack 6.35mm adapter  |
| Color | Brown |
| Impedance (Ω) | 32 |
| Efficiency / Sensitivity (dB) | 108 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 20000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Cable termination | Jack 6.35mm |
| Headphone / Earphone connector | Jack 2.5mm |
